Model 7000 |
Tom Crolwey ![]() Bronze Level ![]() Joined: 03 May 2019 Location: Odessa MO Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 03 May 2019 at 1:38pm |
My 1976 maroon 7000 will not always start. By "playing" with the pto lever sometimes gets it to start. I replaced the neutral safety switch located behind the battery where the pto engages and disengages. But this did not help. Is there another safety switch, if there is I can't seem to find it. Any help is greatly appreciated. |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22101 |
Another safety switch under the floor mat and thru the cab floor for the clutch pedal.
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 962 |
Welcome to the forum Tom!
The switches are probably good they just need to be adjusted. There is a contact plate on the clutch push rod that typically needs adjustment. You can see it when you look under the front of the cab behind the fuel tank filler cap. |
