Model 160 brush mower - HELP
Message Reverse Sort Order
Shirbon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Topic: Model 160 brush mower - HELP
    Posted: 13 Jun 2016 at 9:51pm
Where are springs located if it has springs ? Agcopartsbook doesn't really show it clearly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 9:49pm
If it has springs where are they coated, on the pin/bolt, somewhere in the clutch discs, I have no picture to go by. The diagram on account parts book is not large enough or clear enough to really tell
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 10:33am
Sirbon,
Have responded to PM's and e-mails, including e-mail response sent today. Super busy and do not live on-line.
If you would have included your address in any of the messages, you would have a nice manual in your hands by now . . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 9:11am
If it is a spring loaded slip clutch, there wouldn't be any holes in the middle plate. The 2 outside plates would be bolted with spring pressure trying to pull them together. The middle plate would be squeezed between them making friction the only connection to the gearbox from the PTO shaft.
 The front plate would be connected to the PTO shaft and the middle plate connected to the gearbox input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 8:33am
Yeah, not sure mine has springs if it does I don't know where they are located, though it has hole in frontand rear plates but doesn look like it has holes in middle plate for a pin or bolt. That's why I'm trying to find a picture or a manual or something that will show me what it all looks like. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 8:46pm
I bought new pins and springs for the overrun clutch from Sandy Lake. You can go online to agcopartsbooks.com and view the parts breakdown as a guest viewer.
I did find that on my 160 the slip clutch isn't what is shown in the parts breakdown. Mine actually has a friction clutch where the parts breakdown shows a spring loaded setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 7:10pm
TimNear FortWorth, read your msg the other day tried to pm you don't know it you received it. I'm still interested in a manual or a picture or more help in any way. Thanks
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 7:08pm
First spray the spring area with WD 40, several times, peck on the cast area around the area to see if the springs are rusted and stuck in the holes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2016 at 7:04pm
Try to send a photo but probably won't work for me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 12:56pm
I will see if I can get a picture of my over running clutch tonight when I get home. Can you post any pics. My over running clutch doesn't have plates. There is a spring loaded slip clutch right before the over running clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 10:53am
Still looking for a manual, or a picture, or more help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2016 at 7:27am
Ok timnearfort worth, I pm you, see if I did it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 11:10pm
Originally posted by TimNearFortWorth TimNearFortWorth wrote:
PM me with your e-mail so I can get your address; found a spare manual for that cutter while sorting through my A-C manuals today and can send it to you.
How is that for lending help? Way to go Tim!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 9:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:04pm
If the springs engage the pins, do the pins go all the way through all the plates ?, sounds a bit confusing to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 8:00pm
Ok, so that tells me there should be a pin or bolt through it. The holes in front and rear plates are obvious but the center plate is hard to tell. What appears to be sheared off doesn't look like it really line up with the other holes and looks like it may be impossible to drive it out, looks like maybe only 1 pin/bolt in it though I'm not sure. Any way to get a picture or a manual that shows/tells me more about it and making adjustments etc ?   Otherwise may not be the easiest for me to figure out what to do. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 7:15pm
If "pins" are sheared, cut down some bolts that fit while still allowing it to ratchet when pto shaft turned backwards by hand. Springs need to be good as mentioned so the pins are kept engaged. Just don't go with too hard a bolt stock if you make your own pins and you may need to keep the large adjustment glad snug enough to keep everything mated up right. Tough little cutter, if gear box kept up with grease/oil and grease fittings at base are not forgotten.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 5:46pm
Its an over-running clutch, allows the blades to spin down, without the drive shaft turning.  Take it apart, and see if the 2 pins are stuck, or the springs are rusty and/or broken.  If you need parts, Sandy Lake can get them to you in a day or 3...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shirbon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2016 at 5:42pm
Originally posted by shirbon;101321 shirbon;101321 wrote:
I have and allis brush mower model 160. Seems to slip where the drive shaft connects to the gear box. I'm not sure if there is suppose to be bolts through there, there are 2 holes and almost looks like a bolt is sheared off but doesn't look like it lines up with the holes. Or if it's more like a clutch and needs to be tightened or something. Any Ideas ? Thanks.
