MKll 3500 power plant |
docjrf
Topic: MKll 3500 power plantPosted: 13 Apr 2012 at 7:07pm |
I have a Mkll 3500 turbo power plant Onan. Last thursday when runninig it for 7 1/2 hours I developed a fuel leak on #4 cly injector tube. I contacted my local dealer and they said that the part number (4029482-9) is no longer available. Any ideals as where I could find an injector tube. The Model #mk-ll 1-7451-81631 Serial #3d58144.
Thanks for any Help
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Thanks(1)
Posted: 13 Apr 2012 at 8:26pm |
If a new one is NLA even through some of the Allis sources here AND a used one can't be located in a reasonable time frame then the line should be able to be repaired by a quilified welder. This is a somewhat common repair in the diesel world.
Yea, I can fix that.....
Thanks(1)
Posted: 13 Apr 2012 at 9:41pm |
If the line has failed right at the injector, you may be able to cut it off 1/2" and add a new nut a farrel to repair. Yeah, that isn't the right way to do it, but it does work cause I've done it before.
Lazyts
Thanks(1)
Posted: 13 Apr 2012 at 11:02pm |
Try Illini Construction Parts, listed on this website- I purchased a new injector line for an 11000 MK2 engine from them recently. He had to get it built, but it was well built, as good as the factory ones.
Steve allis dozer
Silver Level Access
Joined: 10 Apr 2011 Location: Australia Points: 232 |
Thanks(1)
Posted: 14 Apr 2012 at 3:52am |
was some on ebay under fiat allis , the shop onan generator parts
regards steve
docjrf
Posted: 14 Apr 2012 at 5:55pm |
Thanks for all of your info
