Mixing 201 Connecting Rods and Caps |
Post Reply |
wjohn
Orange Level Joined: 19 Jan 2010 Location: KS Points: 1911 |
Posted: 3 hours 57 minutes ago at 7:29pm |
I've been struggling with new con rod bearing clearances in the WD engine I'm rebuilding. Crank was ground .030 under and is right on the money, but a couple of the rods give me .001-.002 INTERFERENCE when I torque them down and measure with a dial bore indicator set to a micrometer for the corresponding journal on the crankshaft. Swapped in several new sets of bearings with no change.
For kicks I grabbed a random cap off of a junk set of rods I have, and voila, the bearing clearance is spot on. I'm thinking there's something up with my engine's original caps. It looks like my options are to either have a machine shop resize the connecting rods, or swap the caps from the bad rods onto these rods. Is mixing and matching caps acceptable or not?
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 748 |
This is not normally considered to be good practice but if the parting lines match and the bore is round (within reasonable tolerance) it should work just fine
Post Reply | |
