Mixed rims/tires |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8409 |
Topic: Mixed rims/tiresPosted: 18 Apr 2023 at 3:16pm |
Just noticed on my tire chart, 11R 22.5 is the exact same size as 285/75R 24.5 is it legal to mix rim sizes on duals, if the tire diameter match?
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35714 |
Posted: 18 Apr 2023 at 3:46pm |
NOT on commercial machines. CAN place 22 tube type alongside 24.5 or 20 tube type alongside 22.5 is all, Has to be similar construction as well. Lo Pros are not same construct as normal size.
Lars(wi)
Posted: 18 Apr 2023 at 3:49pm |
Is it legal to have 11R 22.5 on one side of the axle, 285/75R 24.5 on the same axle on the other side of the truck?
Joined: 11 Sep 2009 Location: illinois Points: 90948 |
Posted: 18 Apr 2023 at 4:06pm |
why would you do that on a truck ? Why would the rims be DIFFERENT to start with ?
Lars(wi)
Posted: 18 Apr 2023 at 4:10pm |
Have a lot of spares in the shop of the two different sizes. Trying to utilize what we have. Most will more likely be put on trailers. |
TomC
Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1549 |
Posted: 18 Apr 2023 at 4:53pm |
Lars,your asking for trouble putting miss matched tires on anything. Coming out of your shop you may have it straight but one blowout and a different shop you'll loose anything and more than you gained. I have seen these guys running up the highway running miss matched tires where one or more of the tires weren't even touching the ground.
DMiller
Posted: 18 Apr 2023 at 5:01pm |
If did ANYTHING, would set a match lot to an axle Full across, then they are not fighting each other, on a trailer even better.
Posted: 18 Apr 2023 at 5:18pm |
yea... i could see one SET of 4 on one axle, and s SET of 4 on a DIFFERENT axle... that might be OK. ... but all should be the same on one axle.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 19 Apr 2023 at 10:27am |
DONT DO IT!!!!!!!!!!!!!!! you are settin yourself up for serious charges by DOT! THATS the exact thing they look for and usually the first! --- Trust me they do NOT miss that point!
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 21 Apr 2023 at 1:24am |
+1 on what AC says. DOT will NOT pass a mix-match. One thing you certainly do NOT want to do, is have a mismatch between tires on an axle, and the NEXT thing you do not want to have, is a mismatch between front and rear axle in a both-driven circumstance. The smaller diameter, even if miniscule, will fight the larger, and you'll wind up with very high tire heating as a result. Even with an interaxle differential, you'll wind up with tire heating. Mismatching tire width to rims is bad, and running mismatched tires in a dual is bad. When you look on the tire sidewall, there's a load rating in SINGLE, and a load rating in DUAL. The reason for the difference, is tire heating. In a single application, equal airflow is available to cool the inside and outside of the tire and wheel. In a dual, the space between the tires is significantly higher, because there's two wheels and tires who's heat is radiating towards eachother, rather than moving away, and the brake system is shrouded substantially by the second tire's presence. The wheels serve as a heat-sink, but the outer does NOT conduct heat away as fast as the inner because the interface between the two wheels is inherently a thermal insulating barrier... the inner wheel face gets hotter. The end result, is that the running temperature of duals is HIGHER than singles, so the tire's capacity must be de-rated to accomodate the tire temperature. This is also why SOME tires have TWO pressure ratings... one for single, and one for dual. MOST manufacturers won't, they'll just use the lower of the two, but SOME do. This is also why there are some tires rated for STEER position, while others are rated for DRIVE POSITION ONLY... the drive tire structure is optimized for a particular load and operating temperature profile under compression, thrust, and braking, while the steer tire's structure is optimized for greatest durability under steering and braking loads. The steer position tread design is usually optimized for handling stability. And please... NEVER mount them with fire.
