Mix & Match D17 Power Steering
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: Mix & Match D17 Power Steering
    Posted: 09 Nov 2011 at 11:21pm
I am trying to put a series 4 ps on my early tractor. I moved the generator back and thought that I could use the double pulley to drive ps. The fan belt lines up but the ps pump doesn't. I guess I will have to break down and pull the front bolster and put the double pulley on the crank. I also have to order the suction tube fitting that goes into the bolster. Mine has a modified diesel setup on it, and the series 4 is different.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 8:21am
Is that the same pump that goes on the D-19? Looks very similar.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 9:59am
Yes the pump is the same.
This page was generated in 0.119 seconds.
