Milking Time
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Milking Time
    Posted: 12 Apr 2025 at 10:35pm
Grandsons using the Model C to power the Surge milking machine. If you look closely you can see the radiator shutters inside the grill. Thank you Paul B Smile
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 11:02pm
thats how we done it when the power whent out except we used the 66 chev pickup
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 12:26am
What's the deal? Just drive the milker to Betsy and do the deed? No stanchen or barn needed.
Edited by SteveM C/IL - 13 Apr 2025 at 12:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 4:31am
That's what I would call a cow-er take off...LOL
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 5:45am
Dad had a hose that ran from the tractor to the vacuum line in the barn for when we lost power. IIRC, we could only run two milkers, instead of the four we usually used, but it was a lot better than milking by hand!
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 6:09am
My dad had a milking machine petcock on the CA intake manifold also. It was used every couple years, usually after a lightning storm knocked out the power. I can't recall if it kept one or two milking machines going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 6:54am
Glad to help with the shutters
 What are those side frame mounts for? They look to be quite substantial.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 10:27am
This tractor came to me with a bodacious front end loader that a previous owner had installed; it kinda-sorta worked but is really too heavy for a Model C. I left the mounts on to function as engine weights.
This page was generated in 0.057 seconds.
