Military surplus 3500 generator engine in a D21 |
| Author | |||
pirlbeck
Joined: 01 Dec 2009 Location: West Central IA Points: 248 |
Topic: Military surplus 3500 generator engine in a D21Posted: 08 Jan 2026 at 10:51pm |
I have spoken for a rebuilt military surplus 3500 engine with the intentions of putting it in a D21 with series ll conversion that I have had sitting here way too long waiting for me to rebuild an engine to put in it. I am aware that the timing cover, the front engine plate and hydraulic pump drive will need to be swapped from the D21 engine to the new engine.
I don't know if the rebuild engine has a crankshaft driven oil pump or the earlier cam driven oil pump, but will the oil pan on a 3500 engine with the crank driven oil pump clear the D21 front axle without modification? This rebuilt engine also has a right angle tachometer drive coming out of the tach drive location on the block, so it either has the cam driven oil pump or some sort of stub tachometer drive. I am also aware that I will need to swap a lot of the engine accessories, most of the fuel system, along with the rear engine plate and flywheel. I would like to to look as close to "stock" as possible so I plan on using the D21 parts wherever possible. Any other possible surprises that I may not be thinking of? Thanks!
Edited by pirlbeck - 08 Jan 2026 at 11:16pm |
| Sponsored Links | |||
PeteMN
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 206 |
Posted: 08 Jan 2026 at 11:16pm |
Steve Fisher probably knows as much about those military engine conversions as anyone. He sold a bunch of them.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5171 |
Posted: 09 Jan 2026 at 8:20am |
Strip it down to a long block, and go back with the D21 parts as needed. They are both the early style blocks.
Michael V (NM)
Posted: 09 Jan 2026 at 10:17am |
I was gonna do this with my 220,, but,,with the help of this forum , hav pretty much figured out that it more than likely has the original engine,, so I'm jus gonna rebuild it..
That being said,, I now have one of these military rebuilds for sale,, still in the crate... |
orangereborn
Posted: 09 Jan 2026 at 1:52pm |
if the engine conversation is about the unit Lad/orange knight had listed, this should be the engine tag.. Would not that tag be toward the end of the series? Thanks...Dale
Edited by orangereborn - 09 Jan 2026 at 2:03pm |
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 800 |
Posted: 09 Jan 2026 at 2:32pm |
If you want the original Allis Chalmers engine tag on the military block, we stock both the tags and the rivets so it looks original
pirlbeck
Posted: 09 Jan 2026 at 2:40pm |
We have put 2900 combine engines in tractors before, so I know there is a fair amount of parts transferring to be done. Thanks for the help!
pirlbeck
Posted: 09 Jan 2026 at 2:44pm |
My block has a hole in it behind the hydraulic pump so there is no rebuilding it. When I bought the tractor it came with a short block that looks like it has sat outside with not head on it. My intention was always to just rebuild it, but as expensive as parts and machine work are I think this rebuilt engine will be a cheaper way to go. Thanks for your input!
pirlbeck
Posted: 09 Jan 2026 at 2:55pm |
Yes, the engine is the one in the classified here listed by Lad. Besides the factory style tag on the rear LH corner of the block, the picture also shows another tag farther forward on the LH side........maybe this tag has some rebuild SN or component information. If it is that late of production engine, would it likely have piston cooling jets in it? Thanks for your help!
pirlbeck
Posted: 09 Jan 2026 at 3:06pm |
I will keep that in mind, depending on how original it ends up looking. Can you stamp the tag? Thanks!
Michael V (NM)
Posted: 09 Jan 2026 at 3:20pm |
Well,, a hole in the block don't leave much choice mine still run,, although it's really tired,,
pirlbeck
Posted: 09 Jan 2026 at 3:50pm |
pirlbeck
Posted: 09 Jan 2026 at 5:24pm |
Lad sent me a picture of the tag and as you stated, it is the same date of MFR and the same engine SN as your picture above. Is the date of MFG and the engine SN the original one from Allis when the engine was built? I would think it would be. Anyone know what the A suffix means in the model number? The other tag shows the rod and mains as being .010 & .010 and overhauled at OSMS, OREGON Thanks! |
concretepumper
Joined: 02 Jun 2014 Location: Wentzville, mo Points: 94 |
Posted: 09 Jan 2026 at 8:50pm |
I have done this swap on 2 d21s and a 210, the ones I have swapped in all had the front crank shaft driven or 210 style oil pumps
As ed mentioned, I stripped the long block down and exchanged rear covers If the motor is crank driven, you will need a deep 210 style oil pan and front cover The deep oil pan does clear the front axle One of the differences I found are the cranks do not have dowl pins for the flywheel, they have Japan cranks, and standard rods One thing I would for sure check is the oil cooler, finding out the hard way, sitting in storage, the copper in the cooler had deteriorated and upon start up, mixed coolant with the oil Other than that, pretty straightforward, I use one in a 210 pulling hot farm class |
Posted: 09 Jan 2026 at 9:56pm |
The suffix "A" would mean it is a first generation 3000 series engine. This would mean the oil filters are positioned to run oil down the side of the block when you remove them and if equipped with an oil cooler (turbo'd engines) it is vertical in location right behind the injection pump. Typically, we would see them in D-21, 210 and 220 farm tractors. I don't think piston cooling jets would be there as the cam driven style oil pump didn't have enough GPM's for that feature, or maybe they blocked the jets with the blank main bearing shells? . The crankshaft driven pump was the same as a 7030/7050 tractor which the 7050 has piston cooling.
Edited by DrAllis - 09 Jan 2026 at 10:04pm |
pirlbeck
Posted: Yesterday at 8:06am |
concretepumper, that is good info on the oil cooler, we will be sure to at least pressure test it.
Would you have an engine SN and date of MFG from any of the engines you installed? I would think with a build date of 5-14-85 it would of had to be near the end of production. I am hoping this engine has the piston cooling jets and the crankshaft driven pump. The only problem with the CS driven oil pump is I will need to find a later oil pan.) Did any of your replacement engines have any sort of tach drive coming off the block, even with a CS driven oil pump? If you go to the classifieds on this site and scroll down you can find an ad by Lad (orange knight) with a couple pictures of the engine I am talking about. Thanks!
Edited by pirlbeck - Yesterday at 8:45am |
Kcgrain
Posted: Yesterday at 8:41am |
Yes, we just need a picture of the original tag
pirlbeck
Posted: Yesterday at 8:44am |
Dr. Allis, thanks for the reply.
It will be interesting to get the pan off of this engine to see what it has for an oil pump setup and if it has piston cooling jets. According to concretepumper all 3 of the engines he installed had the crankshaft driven oil pump. With a build date of 5-14-85 I would think it would of been built with the later oil pump and with piston cooling jets, but then again it was built with the old style injectors, so who knows? Thanks again!
pirlbeck
Posted: Yesterday at 8:46am |
OK, good deal!
injpumpEd
Posted: Yesterday at 9:42am |
I've seen some of these engines before, and it seems to me the last ones like this one still had the DC pump, but Ambac bar stock injectors, so to me that is what the 3500A is referencing. To me when the 7030/7050 came out with the newer style block/cooler setup, those 35/3700 series engines were called Mark 1. I think the Military engines kept the original style for interchangeability for their entire run, except the injection lines and injectors, as I think by the time these last engines were built, AC was no longer making their own injectors, so had to go to the Ambacs.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3571 |
Posted: Yesterday at 10:05am |
That matches what I have Ed. I knew Ken Kaply from engine division, he also interestingly stated the military spec on an engine was usually the lowest hp setting on a series recommended, as the engines were built for the longest life possible. The engine oil filters on the one I have use the same as the 8550 cartridge type - but I have see the 74027979 filters used as well.
Edited by tbran - Yesterday at 10:07am |
concretepumper
Posted: 18 hours 38 minutes ago at 3:33pm |
The military motors we have already had the tach drive in them off the cam so the tach cable threaded back like factory, they are not set up like the one in the classifieds
As far as the ones I have delt with, they have all been standard "Japan" rods, not Piston cooling, I've looked at them when changing oil pans Theses are the three tag numbers I can get too 01/75 3d-30660 02/79 3d-61200 1991? 3d-63000 (we sold this motor but kept the tags, '91 is what I believe the cast date was) I have another, but it is still wrapped in the vapor barrier from storage Keep in mind, with the deeper oil pan, the pan is longer toward the front cover to accommodate the oil pump, so a front cover will have to be changed with the deep oil pan, I've pulled both from an N6 engine |
pirlbeck
Posted: 17 hours 44 minutes ago at 4:27pm |
OK, just to clarify, an engine with the crank drive oil pump may still be equipped with a mechanical tach drive setup?
And if it has a crank driven oil pump, besides the deeper oil pan it is also longer so I will need a different timing cover? Are these timing covers that will work with the D21 hydraulic pump drive readily available? Thanks! |
concretepumper
Posted: 16 hours 43 minutes ago at 5:28pm |
On the ones I have done, the tach drive was in them and ran off the cam gear, just as they would of on a factory d21 block
You will need a different timing cover to accommodate the crank driven pump pan As far as the hydraulic pump, it is mounted to the front plate from your d21, timing covers from a tractor will have an access cover for the hydro gear and combine timing covers will not have that access cover, I have used both with no problem |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8784 |
Posted: 13 hours 51 minutes ago at 8:20pm |
I believe all 426's have the gear cut on the cam for cam drive oil pump.
pirlbeck
Posted: 11 hours 58 minutes ago at 10:13pm |
So if I wanted the "correct" timing cover with the hydraulic pump gear access plate I would need to find one from a 210 or 220..... is that correct. Or otherwise any timing cover from a crank driven oil pump engine would work? Will the D21 damper pulley (if it is good) work with the later timing cover? Thanks for your help. |
SteveM C/IL
Posted: 10 hours 35 minutes ago at 11:36pm |
Isn't there some issue about the thinner D21-220 front plate and timing cover concerning clearance for the oil pump drive gear?
pirlbeck
Posted: 42 minutes ago at 9:29am |
It seems like I might of read something once about the front mounting plate being different with the crankshaft driven oil pump. The D21 parts listing no longer shows a part number for the front engine plate, but 210 and 220 both show the same part number which is 74027638. Front plate to block gasket is shown as 74027752 for all 3 models The timing cover part numbers are a follows. D21-74029196, 210-74035338, 220 early SN -74029196, 220 late SN-74029575. It looks like the very early 220 did not have the crankshaft drive oil pump. I am not sure why the 210 and late 220 don't show the same part number for the timing cover. Maybe one is a sub number? Timing cover to front mounting plate gasket is shown as 74035330 for all 3 models. Oil pans part numbers are as follows D21-74029185 210-74036403 220 early sn-74029185 220 late SN-74036403 Crankshaft damper pulley is shown as 74025589 for all 3 models. Anyone have a late timing cover and front mounting plate that they want to get rid of? Thanks!
