Mild WC build
48ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Topic: Mild WC build
    Posted: 25 Feb 2016 at 9:48am
I gotta an unstyled WC with a 201 motor. It has a 4 1/8 bore with flat tops and I'm adding a 45 crank shaft. What carb should I use and what kinda horsepower should I expect. Thanks.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 9:52am
probably the easiest would be a Tsx-464 which is a WD45 carb or the D17 equilivent i dont know the number
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 10:16am
What brand of flat tops? Some don't offer as much compression as stock so HP may be lost.
You can fit a D19 carb on the manifold with some mods to the bolt holes. Your manifold may not work if it is an older one as I think it is smaller than a D17 style
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 12:07pm
I'm not real sure yet on the brand of flat tops. This motor was put together not long ago by someone else with all new parts. I haven't had it long at all and found the webs are split between the sleeves letting coolant in the oil. I'm transferring everything into a donor block and wanting to add some compression with a 45 crank. Just wondering if I should do anything else while it's apart and what carb to feed it with. Thanks
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 12:18pm
Depending on the pistons, you will need new ones. The piston pin hight determines the compression ratio. The crank will drop right in and the rods will work. Pistons might interfere or have sky high c/r.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 12:28pm
If the sleeves have ANY ring edge in them, you cannot install the WD-45 crankshaft and shove the pistons up past the ring edge. If you don't have a WD-45 manifold or newer, you need one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2016 at 5:55am
I would be interested in buying a wd45 manifold and carb if anyone has something they want to sell. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 8:29am
I have a TSX464 rebuilt done ready to install. Its all stock, not tricked up or anything if interested. I can always message it a tick also if need be for pullin'...
Steve@B&B
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 8:34pm
Steve@B&B
Steve, I didn't know you moonlighted as a masseuse...
