Microwave repair
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Microwave repair
    Posted: 31 Dec 2021 at 4:19pm
This is interesting, though might help someone.
I had one of those $89. microwaves for 5 years and it stopped putting out heat a year ago.. I bought another one and put the old one on the shelf thinking i might use the box sometime... Skip forward a year and the NEW microwave does not heat good either.. Takes about 2 minutes to heat what use to take 30- 60 seconds... Looked on the internet and several different "possible " causes related to the  "magnatron" thet generates the microwave waves that get things hot...
FIRST and most simple thing is there is a 4 inch square "window" inside the microwave that is made out of "MICA" ... apparently the WAVES come thru this and the "window" is to keep food from splashing up the hole and get on the magnatron..... The TEST was to remove the mica window and try to heat a cup of water... IT WORKS !! ... So i went out and got the old microwave and tried it.... sure enough IT WORKS..
I have never heard of this before.. The mica "window" dont have to be real dirty.. a little grease or crud smeared on the surface is enough to cut efficiency 50-80%..  You can buy these little mica windows as 5" x 5" sheets and cut to your specific size.. 4 of them cost about $10. on the internet... In the mean time, you can use the microwave without the window, but DONT get food / grease up the port hole toward the magnatron !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 5:54pm
Good advice, Steve. I have replaced a couple of those windows.
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 8:34pm
I've got one that all the sudden the turntable wouldn't work, everything else sounded like it was working but no heat.  Found the door had 2 microswitches, one was bad, $2 later we're heating and turning again.  Never heard of the window thing, wonder how many have been junked because of it?
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 11:07am
Interesting.  I still use the first microwave I bought....in 1984.  Big heavy thing, branded JC Penny, made by GE.  No turntable, plenty of room.  Lately taking a bit longer to heat things....maybe its dirty?
If ignorance is bliss, than happy days are here again.
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 1:00pm
Those first microwaves were very heavy.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 1:01pm
We've still got a microwave we received as a wedding present.  Still works after 36 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 1:09pm
Our "first" lasted 20 years.. NEVER had to do anything to it.. Since then i have had 3-4 and problems more often... Wife set her cook book up against the vent on the last one.. Overheated and the TEMPS SWITCH went out... i have done a couple of them..also on the dryer.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 9:21pm
Steve if you would clean that nasty thing every decade or so you wouldn't have these problems.😜
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 9:41pm
LOL  Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 10:17pm
Thanks Steve, I'm gonna have to check ours out!  Just doesn't have the zip (zap) like it used to.
Steve M Ind View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Ind Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 12:07pm
We still have a microwave just like you describe. JC Penney, big & heavy and wood grain look to it. Got it for a wedding gift in 1987. Still use it daily!!
Gerry D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerry D17 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 8:40pm
Hi all, just a bit of info on working on a microwave. Be aware that they hold a electric charge even when unplugged. Many have learnt this fiddling around with them
sho-man1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote sho-man1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2022 at 8:50am
The most expensive part in a microwave oven is the door interlock switch...That is one thing the MFG does not want to fail, but if it does, it fails with the magnetron shorted to ground. Then the breakers start tripping.
This page was generated in 0.215 seconds.
