Meat Grinder ? |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Topic: Meat Grinder ?Posted: 24 Nov 2025 at 6:21pm |
Borrowed a friends meat grinder to process venison. It did not sound perfect when I cranked it up but worked. Toward the end of my processing the thing went south in the bearing/bushing in the drive end must have gave out. I want to replace it but have yet to find one that has a straight 1/2 inch shaft on the end for the pulley to fit on. Anyone been there/done that and found a source for one with a straight shaft as opposed to the normal ones that have the tapers on the shaft that the crank normally mounts? thanks
Edited by Dave H - 24 Nov 2025 at 8:36pm |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 25 Nov 2025 at 6:23am |
Dave H, sorry you’re having difficulty. Should be a more pleasant experience - right? Please provide more info. What’s the brand, model of the meat grinder in question?
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 25 Nov 2025 at 7:33am |
X2 on make/model, plus pictures would help. You may be able to find a replacement bearing/bushing at a bearings and drives supply. Hobart parts are still available for older models but Hobart = expensive. Is this grinder factory or a modified unit? Best of luck on finding what you need.
Joined: 11 Sep 2009 Location: illinois Points: 90793 |
Posted: 25 Nov 2025 at 7:50am |
could be a manual grinders that had a handle... so the shaft might have been taken out and turned down to 1/2 inch on the lathe to accept a pulley......... better option is a new grinder with combined motor.
Dave H
Posted: 25 Nov 2025 at 9:12am |
Only markings on this grinder ia a big number 10 on the side and Made In China - aaarg
And Steve you are probably right on the crank end being turned down to 1/2 inch. The only machine shop that would mess with that around here has gone belly up a long time ago. I am going to start sniffing around foer someone who has a lathe for hobby stuff.
Edited by Dave H - 25 Nov 2025 at 9:19am |
Posted: 25 Nov 2025 at 9:55am |
i took one of those cheap China corn grinders and turned the shaft down for a pulley.. Worked for a few hours, then broke as you noted... Not really made to do that. Hand cranking is different than putting a side load on with a motor.
Dave H
Posted: 25 Nov 2025 at 11:04am |
The saga is over. Talked to the owner and he recalled that it was well used when he bought it 40 yeays ago. So the grinder is going to the scrap pile today and the thing is a back burner project for who knows when. Happy Holidays folks!
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 25 Nov 2025 at 12:28pm |
I have an old hand crank meat grinder that has a big 22 casted on it. It's currently boxed up and I forget the name brand. I'd sell it for $75 including postage anywhere in the lower 48.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11397 |
Posted: 25 Nov 2025 at 1:33pm |
my son just brought his for me to use and it's a Cabela.
