Meat Grinder ?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: Meat Grinder ?
    Posted: 24 Nov 2025 at 6:21pm
Borrowed a friends meat grinder to process venison.  It did not sound perfect when I cranked it up but worked.  Toward the end of my processing the thing went south in the bearing/bushing in the drive end must have gave out.  I want to replace it but have yet to find one that has a straight 1/2 inch shaft on the end for the pulley to fit on.  Anyone been there/done that and found a source for one with a straight shaft as opposed to the normal ones that have the tapers on the shaft that the crank normally mounts?  thanks
Edited by Dave H - 24 Nov 2025 at 8:36pm
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 6:23am
Dave H, sorry you’re having difficulty. Should be a more pleasant experience - right? Please provide more info. What’s the brand, model of the meat grinder in question?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 7:33am
X2 on make/model, plus pictures would help. You may be able to find a replacement bearing/bushing at a bearings and drives supply. Hobart parts are still available for older models but Hobart = expensive. Is this grinder factory or a modified unit? Best of luck on finding what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 7:50am
could be a manual grinders that had a handle... so the shaft might have been taken out and turned down to 1/2 inch  on the lathe to accept a pulley......... better option is a new grinder with combined motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 9:12am
Only markings on this grinder ia a big number 10 on the side and Made In China - aaarg
And Steve you are probably right on the crank end being turned down to 1/2 inch.  The only machine shop that would mess with that around here has gone belly up a long time ago.  I am going to start sniffing around  foer someone who has a lathe for hobby stuff.
Edited by Dave H - 25 Nov 2025 at 9:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 9:55am
i took one of those cheap China corn grinders and turned the shaft down for a pulley.. Worked for a few hours, then broke as you noted... Not really made to do that. Hand cranking is different than putting a side load on with a motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 11:04am
The saga is over.  Talked to the owner and he recalled that it was well used when he bought it 40 yeays ago.  So the grinder is going to the scrap pile today and the thing is a back burner project for who knows when.  Happy Holidays folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 12:28pm
I have an old hand crank meat grinder that has a big 22 casted on it. It's currently boxed up and I forget the name brand. I'd sell it for $75 including postage anywhere in the lower 48.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2025 at 1:33pm
my son just brought his  for me to use and it's a Cabela.
