Meat Grfrinder |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3593 |
Topic: Meat GrfrinderPosted: 1 hour 20 minutes ago at 6:21pm |
Borrowed a friends meat grinder to process venison. It did not sound perfect when I cranked it up but worked. Toward the end of my processing the thing went south in the bearing/bushing in the drive end must have gave out. I want to replace it but have yet to find one that has a straight 1/2 inch shaft on the end for the pulley to fit on. Anyone been there/done that and found a source for one with a straight shaft as opposed to the normal ones that have the tapers on the shaft that the crank normally mounts? thanks
