Mean Machine
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Topic: Mean Machine
    Posted: 26 Oct 2011 at 12:07pm
Not Allis but if I had one......
[TUBE]QVAJT2ThP-4[/TUBE]
190xt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 12:38pm
 That Thing  Works Really Good
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 1:22pm
It does work really well, but I ask this, how many stumps can you back up to with a 250+ HP tractor, that weighs over 10000lbs, and the home owner won't mind the ruts???   :-)
Still in use:
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 1:26pm
I would hate to hit a big rock with that.
The joy is in the journey.
AC "B" and "WD" and "C"
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 2:02pm
   An 8100 is a 180 hp tractor. And as far as the weight, probably is no more than a backhoe. If the ground is fit, should be no ruts.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 9:46pm
I would imagine it intended for clearing pastures and such.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 12:44am
wonder how you would reverse it....like above....if ya hit an edge of a big rock!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 8:34am
How does it do when you hit a big ol' white oak stump thats dried up?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 9:29am
Looks like it really sends shock loads through the tractor
Wink
I am a Russian Bot
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 2:28pm
I like it but I also wonder why it takes such a big tractor. It sure did shake that JD around though.
Also, what about if the center of the stump is rotten?  It looks like the screw pulls it in so does it have enough down pressure to work?
Still, I like the idea.  It's better than those stump grinders that go fast and look dangerous.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 2:53pm
The screw might help guide it but doubt it creates all the downforce. As far as regular stump grinding with chain type carbide tooth chain or blade type with carbide tips I dont think the tractor would leave much more compaction.
 Have taken a lot of stumps out with TLB and the bucket causes more dammage than the tractor weight does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 3:32pm
I watched some other videos and looks like the machine is hard mounted to the tractor.  If the rams are two way then it has down pressure.
M Diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 6:42pm
You can see him putting on down pressure near the end when it gets down to dirt.
Can't help but think of Wyle E Coyote scenario ifn it would stick. Tractor going round and round, driver with surprised look every time he passes by.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2011 at 8:35pm
what is the hp requirements???
jminpa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jminpa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 5:41pm
BearcatnorthMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BearcatnorthMN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 7:00am
WOW that is great.  That looked like a tough elm stump too.  Didn't look too rotten.  What a test!  Hooked up to my WD it would have done the Wiley Coyote thing M Diesel.  I told that to my wife as she was watching it with me and got a laugh out of her
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 9:42am
Christmas is coming soon so if anyone gets my name..................just saying.......
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 10:08am
How long does that blade stay sharp so you cut nicely?? On pine  or rotted stumps no biggie, but fresh cut oak? After hitting rocks it wont work so hot.
This page was generated in 0.387 seconds.
