max rpm?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: max rpm?
    Posted: 13 Aug 2016 at 8:00pm
How fast can you SAFETLY spin a stock wc flywheel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 8:36pm
Most any tractor pull I've ever been associated with, says 3,000 RPM max for any stock flywheel. That is mandated by the INSURANCE COMPANIES who insure the Clubs or Organizations who sponsor the events. Sounds pretty reasonable except, 3,000 RPM on a 2- cylinder Deere ?? really ??.
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 9:26pm
I would not want to be around JD spinning that!
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 11:07pm
most are 10% over stock RPM's . if there checking rpm's after you hook an it's over you will be DQ'' ed''
