Max hp for a 180 and 190 chassis
Allisd21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisd21 Quote  Post ReplyReply Direct Link To This Post Topic: Max hp for a 180 and 190 chassis
    Posted: 26 Mar 2018 at 3:25pm
Just wondering how much horse power can a 180 or 190 rear end handle. Can they handle over 1500hp
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2018 at 4:03pm
Id say an XT 190 series 3 rear end could,, I bought a 180 that had a 4 charger set up on, pulled the rear axles once and the splines were twisted a quarter turn,,, lot of stress there !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 7:23am
The 190 or 200 will handle more because the final drives are stronger. I know of several 180/185's that are in the 1200 HP range without failures and know of one that did completely destroy a final drive. Pretty sure there was a triple turbo 180 from Kansas that would have been 1500 ish and if he's still pulling it, it must be reliable enough to keep pulling it at that HP level.  Modern (easy starting) pull sleds and short bar rear tires play a huge role in driveline life. Any tractor/driver that can't figure out proper tire pressure and where the chassis weights belong will have unsmooth runs down the track. Smooooooth is gooood for the driveline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 1:10am
Back in the 70s we were putting about 1500 hp into a Farmall M rear welded into 5th gear and twisted both rear axles like that. The main thing with higher horsepowers is to avoid the temtation to weight smaller tractors down to run in heavier classes, that is a sure way to invite desaster
This page was generated in 0.150 seconds.
