Max 8070 hp
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 10:06am
If your answer is the only safe HP is as designed, that's totally fine by me.  I don't have a single turned up unit on my farm, or even an engines swap.
The question is kinda moot because the safe hp is what it came out with. Sure you can push it beyond that point if you want but I wouldn't put much more than stock hp to the ground. What gets to the ground depends on how much you weight it down. So maybe the question isn't moot it is just too subjective to satisfy everyone. But I am a believer that the owner can do whatever he/she feels like.
BTW I run on mountain dew no coffee for me. Not enough norsk in my blood.
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 10:16am
Originally posted by tornado8070 tornado8070 wrote:
Original post also forgot to mention the 3 engine on hand. Besides if they are used it would be silly to go through all the work to shove a engine in without rebuilding it prior. And you still can't rebuild a Cummings cheaper than a 426, when doing a complete rebuild.
The original POST did not mention the 3 engines.  The original postER did, which is what I said.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 10:47am
Tornado.   I have a converted 7580 that the guy that did it honestly made it look factory.   Radiator cools better than my stock 8030 does.and the 8030 is a recent recore with all the foam in place. Hood panels are intact exhaust is routed out the factory hole. No oil leaks and dash is stock except the push pull knob is disconnected and it has a dial oil pressure gauge. Sometime your in my area stop in I'll show you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 10:54am
Never said I had 3 sitting around I have 3 in service. The 8.3 in other applications runs 260 hp at close to that point it would get tempting if it could be somewhat harnessed.
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 10:59am
I could respect a neatly done repower, I still won't do it on my tractors. Victory if your ever over this way your welcome to stop in as well. If you wanna push an 8070 chassis put it in one with a PD.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 11:30am
I'm still curious about what you mean by pitfalls of an articulated tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 1:41pm
1) In my experience they cost more to own.
2) Take more shed space.
3) Hinge area needs frequent greasing some of the U joints are a real treat.
4) Outside of Allis and the pre 60 series Deere most are bareback.
5) Nearly impossible to see the drawbar when hooking up.
In the end odds are I'll buy another. just exploring my options.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 7:44pm
Maybe  pop corn with that beer!
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2017 at 10:13pm
Find and early one with the big finals, and a power director, set it at 245 and let it rip. That's what ours is set at. How big is your finisher? We pull a 22 ft sunflower, could probably pull 24. Your 7580 would pull a 15 knife aa bar in rolling ground, our 7080 would only pull 13, I run out of traction before power.
Edited by Dkienzle - 28 Jul 2017 at 10:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 5:25am
31 foot but toyed with a 25 foot or so.
Austin IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 8:22am
Buy an 8550 and have about $10,000 left in ur pocket. You won't have to worry about lack of hp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 8:25am
More hp because of the pump of course, not because of the engine
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 2:41pm
Austin Lol!!
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 6:02pm
Laugh away, take your beloved B or C series Cummins and put a little Rosa master pump on it rather than the P pump and let me know what kind of power you have or feel. We'll see who laughs than😎
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 6:53pm
KCgrain i usually laugh every time i see u post.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 8:44pm
Now boys behave
Wink
I am a Russian Bot
