Marvel-Schebler carb on a CA |
Dean(IA) ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: NE Iowa Points: 430 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jun 2017 at 8:29pm |
Does anyone have the dimension on the throttle shaft arm,center to center,
from the throttle shaft to the governor rod hole? thanks, Dean |
wd4d5 ![]() Bronze Level ![]() ![]() Joined: 30 Apr 2014 Location: pleasant lk mi Points: 2 |
I'm not sure if it's the same as a C if so i can take a dimension off of mine and let you know if you still need the info.
Jim-Ohio ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Cols.Grove,Ohio Points: 335 |
What is the correct Marvel-Schebler carb TSX number for a CA?
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11994 |
I believe the TSX-670 is the popular Carburetor for the CA. There are some other Carbs that could've come on the CA also. TSX-470, TSX-486.
Steve@B&B |
