marvel schebler |
lost in h3 ![]() Bronze Level ![]() Joined: 06 May 2023 Location: missouri Points: 71 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Aug 2023 at 9:37pm |
My h3 has a marvel schebler carburator which is a TSX879. I need a complete kit plus both shafts and choke butterfly. Does anyone know what kit will work with this? No one has a kit for a TSX879. Would a TSX878 WORK?
Jim.ME ![]() Orange Level ![]() Joined: 19 Nov 2016 Location: Maine Points: 941 |
Don't know where you have been looking but here are a few possibilities. Most kits won't have the hard parts (shafts and choke butterfly) you are looking for. Standard Motor Products shows the TSX879 for an H3. Their kit number for it is 1302. Steve at B&B Custom Circuits rebuilds carbs and can likely help you with the parts. McDonald Carb and Ignition likely has a kit and hard parts. There are many others.
Edited by Jim.ME - 05 Aug 2023 at 6:49am |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8204 |
Do you know what part numbers are for the hard parts
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19740 |
A WD-45 carb is almost identical to a D-15 series 2 G-160 engine. Throttle shaft is different but the WD45 shaft could be modified to work. Choke plate is the same.
226453 choke plate ![]() 226445 says use 231437 ![]() Edited by Mikez - 05 Aug 2023 at 9:13pm |
Mikes
Do you think a wd45 carb kit would work?
Dr said there similar Those are from a wd-45 parts book.
