Marvel carb
oldfords View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldfords Quote  Post ReplyReply Direct Link To This Post Topic: Marvel carb
    Posted: 18 Jun 2024 at 8:57am
Where can I get new packing for the load adjustment screw on my D17 tractor? The screw leaks a little and will not stay tight, I tried tightening the nut, but still the same problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 9:59am
i would guess you carb model is a 773 on the D17 .... There are "small kits" (gaskets) and "larger kits" that would contain more brass or steel parts.... i would THINK that anything you needed would be in that kit..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 10:03am
Well, if its a Marvel, it should be a TSX-773,869 , or 871. I would check to make sure its the correct Carb first. Sometimes over the years, Tractors get different Carbs put on them unless its been in the family since day one and you know it hasn't been changed. I carry some in stock. Find out the Carb # first and we can go from there....
Steve@B&B
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 11:10am
I don't know why they don't put these in the kits.I have yet to find a kit that includes them.Seems pretty silly to me.Here's where I found them.Roberts carburetor repair.It's #34 in the pic.scroll down the page to see it.Although your carb number isn't in this list,this packing does fit your application.The carbs listed on this page are large bowl marvels as is the carb used on D17 so most of the parts interchange.I bought a half dozen or so when I found them as I have several old A/Cs around here.Hope this helps you out. http://robertscarbrepair.com/carburetor-parts/marvel-schebler-tsx-m-40-320-330-420-430-440/
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 1:11pm
Not included in the kits ?? Man, somebody screwed up there... So its similar to the fuel bowl shutoff valve on the gas tank.... Maybe wrap a few rows of teflon floss around the shaft and reinstall the nut ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2024 at 11:22am
They were never put in kits because they are considered a "service part" not a rebuild part. That's in the same category as floats, venturi's and nozzles.
Steve@B&B
