|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Maroon/Black BELLY ? |
| Post Reply   |
| Author | ||
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Topic: Maroon/Black  BELLY ? Posted: 19 Apr 2022 at 7:01pm | |
   Seems like the 7060 carried on the # between the maroon/black belly, were there other models that did? What made ALLIS dump the 7050/7030 for the 7045 ? Thanks
| Sponsored Links | ||
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Apr 2022 at 7:18pm | |
   The 7030/7050 were the first of the new generation 7000 series in Jan 1973. In the Fall of 1974 the 7040 replaced the 7030. The 7060 replaced the 7050. Each new tractor had 5 more HP and would eventually have the Power Shift transmission. At the same time the 40/60 were released, the 7080 was also introduced, as the largest 2WD tractor built at the time. The 7045 didn't come along until the Fall of 1977.
| Play Farmer   Orange Level   Joined: 13 Jan 2016 Location: NNY Points: 732 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Apr 2022 at 8:37pm | |
   I believe the 7000 was both maroon and black belly, depending on the year.
| AC7060IL   Orange Level   Joined: 19 Aug 2012 Location: central IL Points: 3579 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 8:04am | |
   Heres a link to this topic being discussed in March of 2020. Don’t forget about the 7580 & 8550 4wd models. https://www.allischalmers.com/forum/7000-series-factory-color-combos_topic168853.html | ||
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 6:06pm | |
 Thanks for the post, but wasn't the "red" belly 7000 replaced with the black bellied 7010 ?? | ||
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 6:17pm | |
 What color of the "bellies" were the 75/85 models ??  Thanks for the link BTW !! | ||
| injpumpEd   Orange Level Access     Joined: 13 Sep 2009 Location: Walnut IL Points: 5122 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 6:21pm | |
 No, there was a black chassis 7000 for a little over a year, then the 7010 replaced it. Early 7580 were maroon, later were black, and all production 8550 were black. Quick run down, all 7030, 7040 & 7050 were maroon chassis only.  All 7010, 7020, 7045, & 8550 were black chassis only.  7000, 7060, 7080, 7580 could be either.  | ||
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 6:45pm | |
   Thanks Ed
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 6:52pm | |
 Any idea of what JD 2WD of the 7080 era came close ??  Thanks for the info !! | ||
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 7:08pm | |
   6030 at 175 PTO HP with 531 turbo. 7080 at 181 PTO HP with 426 turbo-intercooled.
| injpumpEd   Orange Level Access     Joined: 13 Sep 2009 Location: Walnut IL Points: 5122 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 7:09pm | |
   Then later the 4840
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Apr 2022 at 7:13pm | |
 Sadly, that 4840 was NOT a bad looking machine   | ||
| AC7060IL   Orange Level   Joined: 19 Aug 2012 Location: central IL Points: 3579 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Apr 2022 at 10:13am | |
 Here's some older AC forum posts inwhich Tbran discusses in length about some it.  Edited by AC7060IL - 22 Apr 2022 at 10:36am | ||
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Apr 2022 at 6:37pm | |
 Thanks for the info7060, but  wasn't JI CASE a decade before the T/L ? | ||
| Ed (Ont)   Orange Level     Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1506 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Apr 2022 at 7:38pm | |
   What is T/L?
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(1)  Quote  Reply  Posted: 22 Apr 2022 at 7:59pm | |
   Torque Limiter
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Apr 2022 at 8:24pm | |
   There is a post in the classifieds for a 7060, this machine has "spin-out-power-adjust" wheels   . Why did ALLIS drop them after the XT era and then bring them back? Or did this machine in the add have some type of aftermarket rim/wheel set-up ? | ||
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Apr 2022 at 8:35pm | |
   You are a little confused. The power shift rear wheel was introduced in 1948 on the WD tractor. It continued thru the 175/185 tractors until 1981, nearly 33 years as standard equipment. The 6060-70-80 tractors also still had them. Why is that ?? Because there was no other way to adjust the rear wheel tread !! None of those tractors had a "bar type" rear axle. The D-19 and D-21 had bar axles and the power shift wheel then became an OPTION as it was more expensive than the two position rear wheel clamping method. The feature was never dropped. It became an option. Also, since the maybe early 70's farmers didn't need to change rear wheel settings like they used to, so why even have the power shift wheel on larger models ??     EDIT: All 4-pinion 7000/8000 series had to have power shift wheels to achieve 60-63 inch rear wheel tread. This was because engineers had moved the outer axle bearing farther out for strength/reliability. 7045's and up. 8050's and up. Edited by DrAllis - 23 Apr 2022 at 7:04am | ||
| FREEDGUY   Orange Level Access     Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Apr 2022 at 8:44pm | |
   Not confused, just didn't realize it was still an "option" on the larger units .I saw the pic on the classified section and was surprised to see that set-up AND the axle hub assembly  tread adjustment. Thanks for the clarification .
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
