Maroon belly 7000 oil leak from inspection plate
RMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2024 at 11:36pm
Thank you!
I bought the service manuals and the parts manual (kit came with 4 different e-books?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2024 at 6:42am
Regardless. You must stop the external leak first. Then, move on to determining if and how bad a possible oil transfer problem really is.
RMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 12:56pm
Hey guys,
Not sure if I need to start a different thread? But my 3pth won't go down when I have the tractor in higher rims. It raises great, but lowering down requires lower rpm. This will be an issue once I fix the pto problem as the snowblower won't stay on the ground. I've already played around with the traction boost levers but it still does it. Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 1:29pm
Pretty much sounds normal to me. If you've got 500 lbs hanging on it, I'll bet it works fine. Cold hyd oil causes what you are complaining about.
RMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 10:04am
I've got an 8' dual auger Farmking snowblower on it that I can't keep on the ground. I realize it doesn't matter much without being able to use the snowblower until the pto issue is fixed, but figured if it was something internal then I could take care of it while it was split. Thanks again for your responses!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 11:29am
The two rear levers on the console must be clear rearward.
RMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2024 at 9:00am
Thanks, I'll take a look and see where they're positioned.
