maroon 7080 vs black |
19856020 ![]() Bronze Level ![]() Joined: 03 Jan 2015 Location: Hutchinson, Mn Points: 107 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Aug 2016 at 3:55pm |
are there any differences between mb & bb 7080's other than shifter on floor also same question of the 7580 . thanks for any info
716 917 918 1920 d17 6080
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21919 |
Later black models had more lifting power at the 3-point hitch. Very late models had Bosch injectors. Several other little things were changed.
Mike Kroupa ![]() Silver Level ![]() Joined: 02 Oct 2009 Location: pierce, ne Points: 337 |
Maroon chassis 7080 used scavenger pump to transfer leak-off oil from power director housing to the georotor sump housing. Black chassis used a sump under the power director housing and steel tubing to gravity flow oil back to the gerotor sump housing. Much better system. I would think black 7580 would be this way also. Late 7080's had increased 3-point lift capacity. I have a 1980 7080 and mine does not have increased lift capacity. It was a serial number break thing and was carried on into the 8000 series. I'm sure others will add more. Mike
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
If I remember correctly, there were some improvements made to the variable pressure/variable volume pump system also.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Gravity flow oil back to the pump sump was before the end of the maroon series and all 7580's had it, so late 1976 I think.
