Making T-stat Gasket? |
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Apr 2018 at 8:02pm |
Didn't order a thermostat housing gasket(head to housing) for my D17 engine repower. Can I make that gasket and if so, what can I make it out of? Really want to get her running this weekend and can't source it locally anywhere.
AaronSEIA |
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13696 |
Hey Aaron,,O'Reilly's has a "kit" of 4-5 different material and thickness gasket making material that will do the trick for you. ![]() ![]() |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54118 |
Beer box, and a tube of blue goo...
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8628 |
could just use light smear of rtv alone
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
I've heard of that being done quite a bit. Sometimes without the blue goo even...
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
Order one from your local AGCO dealer. They will courier it out to you (for a fee) and you will get it in a couple of days. You know it is the right one you need too.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21899 |
Clean both surface with brake kleen and use good quality RTV and you will be fine.
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3583 |
I would go with the good RTV as suggested.
I recall the ole beer box gaskets deteriorating with time. |
Get your gasket paper, clamp the housing upside down in a vise, lay the paper on the housing and tap the edges of the housing through the paper with the round end of a small ball pein hammer. You'll end up with a perfectly shaped gasket that fits right. |
