Making a WD into snap coupler
jminpa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jminpa Quote  Post ReplyReply Direct Link To This Post Topic: Making a WD into snap coupler
    Posted: 28 Mar 2010 at 4:42pm
I just got a WD and it doesn't have a snap coupler and i was attempting to put the hitch on it and it is just a pain to do and i saw a video of the factory people putting a hitch onto a WD-45 with snap coupler and was wondering if you could convert a WD into a snap coupler and how.  Here is a link for the part i would like to put on my WD
http://www.wengers.com/parts/Farm-Tractor-Parts/Allis-Chalmers/WD45/WD45/Drawbars-Hitches/Snap-coupler-hitch/SNAP-COUPLER-BELL-ASSEMBLY/01-237301.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 5:00pm
Farmers have been doing it since the 45 came out in 1953. You will need way more than what is shown in the picture though. You need the hook,the release lever with mounting and chain, a spring for the hook. By the prices on that link, you'd be better off looking for a parts tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jminpa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 6:51pm
Thanks for the input CTucker and  with that said does anyone have a picture diagram of how to hook up the snap coupler to a WD?
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 7:05pm
  just make sure you get all linkages for the hyd. pump   we have it all
  1-800-254-3116 will need to ship in2 packages [ costly]
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 7:06pm
I also converted my WD last summer when I got a mounted plow for it. as mentioned above there's more to it than that piece you have. a word of warning especially if you plan to plow: YOU MUST GET THE LATCHES FOR THE LIFT ARMS!!! there are a few on here who can tell you horror stories of the plow hitting a rock or something and coming unhitched from the bell underneath but not the lift arms and the driver becoming an allis sandwich when the plow flips up and over. this is good advice for any implement but particularly plows. ONLY use the snap coupler and latches together. it is a great system that works when used properly. best to look in salvage yards or ebay for parts $76 is way too much for that bell. good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jminpa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 7:17pm
I don't have any of the parts yet and hopefully will be able to find them all in a bundle together for a affordable price. I just posted the link for the picture to find out if a wd-45 bell would be able to be put onto a wd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 7:26pm
all snap coupler parts are the same for wd/wd45, there are several styles of lift arm latches also but any of them will work
bucksnortAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bucksnortAC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 7:41pm
i have the bell and release lever assy $75 shipped.  buckagg@yahoo.com
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 9:52pm
 Where in Pa are you Jim? Yinglings Equiptment in Gettysburg might have everything you need 717-359-4848 if not bucksnort sounds good too. I have an extra set, but hesitate to part with it for $75.oo. Good luck...Harvey
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 10:18pm
DO NOT and I repeat DO NOT do business with Wengers. They are about 20-30 miles from my place and are scrooges when it comes to parts in my opinion. They are always over-priced and are not flexible at all. I don't know how they stay in business. You can get a lot better quality parts from a lot better quality people here on this site. I'm sure somebody will hook you up. If anyone has a problem with my opinion, feel free to PM me and I'll back it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 10:20pm
Like Harvey asked, where in PA are you located Jim? Seeing Wengers site leads me to believe you are in Lancaster/Lebanon/Berks area? If you are, and need something local, I might be able to connect you up with some local parts guys that can get you everything you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jminpa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 4:16pm
I'm in Chester county near Morgantown, PA
This page was generated in 0.163 seconds.
