Making a belly mount blade for WD |
Osage_Orange ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1593 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Apr 2011 at 11:28am |
Has anyone here made or seen a good one? My rear mount is just too crude to do a good job of grading my gravel driveway. (front of tractor goes up -- blade digs in gravel, etc). I thought about trying to make one from the front part of a cultivator (but don't have a cultivator, ha) Pictures or links would be helpful.......tx
Why is there never time to do it right the first time, but always time to go back and fix it?
Dave Richards (WV) ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
Mr. Double "O", think about bolting a pair of wheels behind your rear mount blade.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3962 |
I have one that I built for my C you could build a similar on for a WD.
If you look on your final drived there are bolt holse fwd and aft of the Axle nut Cap. that is where the drop brackets for the #3 mower attach. just run push braces fwd from there. make sure you put a swivle in one side. I welded at fixed angle and used pulleys and cabled to lift. I only used a section of grader blade cutting edge for the blade. I'll try to get photos when the weather lets up. we had 2 " of snow today.
Dennis(IA) ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: IOWA Points: 356 |
I have wanted to do the same thing on my wd45. That would be great for blading the driveway. I know that I'll never get it built because I retired last year and now I will not have time.LOL
Dennis
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
One of these days I'm going to make one for my G. I know how I'm going to do it, just haven't done it yet.
Dusty
Here are pictures of the One on My C
and the drop brackets on WD45
The blade works very well for grading the road. I've also used to shape fill in pole buildings.
LloydCentWi ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Wisconsin Points: 300 |
The G would make a great grading tractor.
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5891 |
Fred cheats... ;-) He BUYS 'em 'factory built'...
Edited by DaveKamp - 20 Apr 2011 at 9:09pm |
acd21man ![]() Orange Level ![]() ![]() Joined: 07 Jan 2010 Location: tn Points: 831 |
Osage_Orange
![]() lol maybe my color is fixed now lol |
Dave Richards: I made a setup w/wheels, but it's difficult to get adjusted and difficult to make changes. Had a belly blade on a F**m**l cub once......it worked great........but got rid of the cub.
Dakota Dave: Tks for photos. Looks simple enough (much simpler than trying to hang one from cultivator arms). I'll have to figure out a way to raise/lower it.
Fred: Tks for photo. May incorporate some of that design into whatever I end up building. If I had that rig, would have to park truck outside and put grader inside. ha ha
ACD21man: It's just a brush guard to keep me from getting knocked off tractor while brush hogging. Made from 1-1/4" and 3/4" sch 40 pipe.
Edited by Osage_Orange - 20 Apr 2011 at 11:32pm |
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3860 |
Several years ago I added about 5ft. to the frame of a WD, then made a 10ft. grader blade that hyd. angles to a 45* angle both ways. The hyd pump on the WD is low volume and works great. It also has a wide front.
Claus ![]() Orange Level ![]() ![]() Joined: 09 Dec 2009 Location: Hebron In Points: 1152 |
I would like to have one of these behind my 170 but cannot justify the price.
http://www.hoelscherinc.com/prod_grgrader.htm |
pa steve ![]() Bronze Level ![]() ![]() Joined: 28 Oct 2009 Location: howard pa Points: 18 |
I BOUGHT A C THAT HAD A WOODS BELLY MOUNT MOWER ON IT.
THE GUY SAID HE HAD A BLADE THAT WENT WITH TRACTOR. SO INTO THE WEEDS WE WENT TO FIND THE BLADE. HERE IT WAS A WOODS BLADE (LIKE NEW)THAT FIT ON THE BRACKETS THAT THE MOWER USED.WORKS GREAT PLOWING SNOW AND GRADING MY LANE |
KenBWisc ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1183 |
I have one I built for a G I'd sell. Works and looks good!
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Ken, I think I can build one cheeper than I can drive to WI. and buy yours. But I'd like to see a picture of yours.
Dusty
I'll try this for posting a photo of my belly mount blade I made for my G. Hope it works! This process is not intuitive to me.
http://www.allischalmers.com/new/forum/file_manager.asp?UL=true&FN=Picture1.jpg |
