Main jet size Alli C , two fuel
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Main jet size Alli C , two fuel
    Posted: 12 Jun 2022 at 9:40am
Hi
My Allis was in configuration af 2 fuel gasoline and petrol/TVO
Now i use only gasoline, never more petrol.
Do you think i have to change carburetor adjustment? for example main jet size? or to buy another set of jet?
I have a ZENITH model 61. What is the right main jet size for gasoline?
It is Non-adjustable power jet. but may be i have to put a Needle set for Fuel Adjustment?
Edited by John426 - 12 Jun 2022 at 11:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2022 at 1:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2022 at 4:13pm
Leave it alone. It will work fine. Fine tune it as per your repair manual and leave it be. When I rebuild dual fuel Carburetors for customer's, I put the same jets right back in after a total rebuild unless the jet is messed up from someone trying to get the jet out without the correct tool. Then they send the Carburetor to me...  Angry
Steve@B&B
