magneto |
Post Reply |
acd17toy
Orange Level Access Joined: 11 Sep 2009 Location: USA Points: 688 |
Posted: 16 Aug 2019 at 7:04pm |
On WC, moving the magneto away from the engine block does that advance or retard the timing?
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
retard, I do believe. I believe the shaft turns clockwise as you face forward looking at the back of the gov housing.
Edited by CTuckerNWIL - 16 Aug 2019 at 7:57pm |
CTuckerNWIL
If the slot in the drive, isn't horizontal, when at TDC, you won't get enough movement out of the mag to get the timing right. Edited by CTuckerNWIL - 16 Aug 2019 at 7:59pm |
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
I was taught to turn the mag closer to the block when starting my WC, then rotate it out a bit once running. If this is correct, then I believe that the answer to your question is "advance".
WC, CA, D14, WD45
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1698 |
I second Dave's answer, tipping the top of the magneto away from the block advances the timing, tipping the top of the mag toward the engine block retards the timing.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Post Reply | |
