Magneto Plug Wires?
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Topic: Magneto Plug Wires?
    Posted: 02 Jul 2010 at 11:43am
Seen many warnings about not using resistor type plug wires with the magneto, and several recommendations to use "solid core" wires.    Are the non resistor wires consisting of several strands of conductor wire also bad for the magneto?  Does solid core mean one larger diameter single wire?   I understand the resistor issue but what is the deal with stranded centers?     Thanks
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 12:01pm
Solid core is the multi stranded stuff. Thats what makes it flexible. Otherwise it would e like house wire. I buy it on the roll at NAPA. They sell all the stuff to make nice OEM appearance wires but you will need the proper Molex crimpers.
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 12:02pm
As long as the plug wires are metal cored with no reister caps  all will be good..........
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 10:16pm
Confusion of terms commonly occurs here-  'modern' automotive wires are actually carbon-strand, and have resistance IN the wire.  You don't want that... nor do you want resistance in the spark plugs.  Resistance is employed to reduce radio frequency interference, however, adding resistance to ignition system means when the coil primary circuit is interrupted, voltage on the secondary side voltage has to rise farther, in order to cause the spark gap to be breached.  Higher secondary voltage is hard on the mag.
I'll second the motion on buying the roll... think I got mine at NAPA too... seems to me it was about $50 for the roll.
This page was generated in 0.046 seconds.
