Magneto for B Switch Hookup |
Fred ![]() Bronze Level ![]() Joined: 28 Jul 2010 Location: Laurel Delaware Points: 48 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Nov 2010 at 9:09am |
My1952 B has a WICO Magneto and it was on there when I bought it. It was hooked up to a key switch which the key was rusted in the switch, wiring was a God awful mess. More tape and wire nuts that the average electrician carrys in his truck. I bought a new on-off key switch such as found on pg. 29 of the Steiner's catalog p/n ABC065. My question is does this have to be wired so you ground the magneto to turn it on?Since I am not doing any other wiring, no lights, no charging system, just the starter, positive ground.
Did I mention that I didn't try to start it since I put the magneto back on, hope I did it right, after painting the tractor since it's still sitting on jack stands. I haven't put water in the new radiator to test for leaks yet either.
Thanks for any comments.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5835 |
You ground the magneto to KILL the ignition. Run is open circuit... and the wisest thing to do, in the case of the mess... is to pull a new wire from the mag to the keyswitch, and also a good ground wire from the block to the keyswitch. Failure to do so will likely grant you a failure to start, or an intermittant run problem, or missing... or best yet, a nasty shock when you reach for the switch.
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
trac tor originally had a on-off magneto [push-pull] switch all it needed was a good ground to tractor 1 wire to magneto only we have those 1-800-254-3116
