Mag question |
B26240
Topic: Mag questionPosted: 29 Apr 2010 at 3:27pm |
I have two Fairbanks Morse mags a FMJ4B and a FMX4B will both work on AC engins ? If not what is the dif? Thanks for the help. Mark L
wjohn
Posted: 29 Apr 2010 at 5:51pm |
They both should work. I have a 1939 Allis Chalmers B that has an FMX4B magneto on it, which was definitely a replacement as the original magneto should have been an FMJ or FMK.
The FMJ4B is what was on most of the B's and many other Allis Chalmers tractors. I can't say for sure that the FMX was actually put on an Allis Chalmers tractor from the factory. The FMX was apparently one of the last magnetos made (and therefore the most updated) before everything switched to electronic ignition. But the FMX mag should work. I'm no expert but this is what I have gathered from asking similar questions about my mag. Hope this helps some.
Clay in MI
Joined: 13 Sep 2009 Location: Upper Michigan Points: 56 |
Posted: 29 Apr 2010 at 7:39pm |
Internally some parts are different but as a unit they are interchangeable. I have swapped them back and forth on B's and WD's.
B26240
Posted: 30 Apr 2010 at 10:39am |
Thankyou wjhon and Clay for answering. Mark
