Machining Ball end of 262D Rocker arms
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Machining Ball end of 262D Rocker arms
    Posted: 27 Feb 2011 at 10:55am
I'm looking over my rocker arms and have a question after I see that the surface that contacts the valve isn't very flat (due to wear).
Has anyone machined these flat?  How was it done?  Are places that do head work able to grab these little pcs and do the machining?
Note the pc I am talking about is not shown in this picture...it is bottom side of where the tape is showing 59".
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 12:27pm
Its usually a curved surface and it slides across the valve. Sometime it hits the valve stem offcenter to make the valve rotate so it might be doubly curved or spherical which complicates regrinding. Then it was probably surface hardened so wear and grinding get to soft metal that won't wear as long as a new rocker.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 12:38pm
That looks like an insert in that end. If it goes all the way through it is probably hardened. I wonder if the insert can be removed for machining?
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:03pm
Many moons ago (50yrs) when I ground valves on an old Snap-on valve grind machine, there was an attachment that allowed you to resurface(grind) the rockerarms back to the original curved surface.  Also the valve stems were also resurfaced to remove the indentation on the end.  We also did a three angle grind on the valve seats. - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:43pm
Yes, the insert can be removed and then by taking out the snapring, this little pc can be removed (Item #11).  I just struggle to see how someone would be able to chuck it up to machine it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 4:05pm
That's a pretty small part to machine. The good thing about that is it's a ball and can pivot as needed. I guess I'm lucky in that all of mine were flat. I only needed 1 complete arm because it got rusty in the ball and socket and didn't move freely and smoothly. New replacements are available, but are not the original ball tipped type. What Al and Gerald are referring to is known as "Re Arching". I'd bet that not every machine shop has the equipment to do that anymore.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:52pm
My van dorn/black &decker valve grinder has an attatchment for re-facing rocker-arms. I have done many of these over the years. Simple and effective. Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 5:43am
Here are some detailed pictures showing the components...has someone been able to machine these small pcs?
It seems to me the item can't be machined in the rocker and would be tough to grab ahold of if it is seperated from the rocker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:26am
no,that style can't be surfaced on my machine. just re-install them. Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:35am
I can't tell from your pic how bad they are, but if you have some that are really bad, call Sandy Lake. They had a few of the old style like yours on hand still.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:46am
I'm thinking those ends look similar to shaft assy on shelf here off 230 Buda diesel, I will investigate if you like. I have 3 shafts w/rockers, one of them may be 262D engine, would you like to but some compete rocker assy's?
This page was generated in 0.578 seconds.
