M Crawler Runs!!! new problems:( |
| Author | ||||
merjamika
Joined: 24 Jun 2010 Location: Ontario Canada Points: 10 |
Topic: M Crawler Runs!!! new problems:(Posted: 09 Jul 2010 at 5:18pm |
I finally got my timing issue figured out on the little crawler, and it runs great. Now what I am running into is that It will not drive on the left side. I took the cap off and can see the drum turning under the brake band. As a rough idea, what would my problem be?
Clutches or something in the drive?
Thanks
Mike Inglis
| Sponsored Links | ||||
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4812 |
Posted: 09 Jul 2010 at 6:20pm |
The teeth on the fiber clutches are probably gone.
merjamika
Posted: 09 Jul 2010 at 7:43pm |
That is what i was hoping....I am going to have to cut a link out of the chains anyways. So thats when i will tear into the housing.
I may have to find some new rollers too
MNLonnie
Posted: 09 Jul 2010 at 8:56pm |
Don't take this the wrong way but you must be crazy if your looking forward to removing the tracks from your crawler. I have one with a dozer blade on it that would sure come in handy around here but it needs steering clutches, it's been sitting out back for 2 years because of that. A couple times a year I fire it up and drive forward and backward with it just to get the parts moving but it won't turn.
CTuckerNWIL
Posted: 09 Jul 2010 at 9:30pm |
merjamika If your track adjustment is to the limit and you tracks sag too much , taking a link out is not the answer. It could shell out the drive sprockets. You are basically trying to change the pitch of the tracks because of wear in the pins and bushings, and you can't change the pitch of the sprockets. Charlie
Edited by CTuckerNWIL - 09 Jul 2010 at 9:32pm |
merjamika
Posted: 09 Jul 2010 at 9:49pm |
Finding parts in our area could very well be a challenge, thats the whole reason for taking a link out, I just want the machine to be able to move without dumping the track all the time. As for pulling the machine apart, I'm kinda used to working on things like that. Plus, I kind of like a challenge |
everett048
Posted: 10 Jul 2010 at 1:48am |
Before you take track off try adjusting steering clutch from top (may be out of adjustment) may be a easy fix but if that dont work then its a tracks off job, have done six m.s so its not to bad off a job todo if you need any advice on how to do leave me a message and will try to help should be able to strip out and repair replace in a day. h t h
merjamika
Posted: 10 Jul 2010 at 5:59am |
I found a set of chains that appear that they might work. They are off of a D2 Cat. I want to take a couple of pads off first to make sure they will work. Are the clutch discs fairly easy to get? The other side of the machine is steering good, but am wondering if I should do both.Mike
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 10 Jul 2010 at 12:02pm |
If the bushings are still good you might look at having them turned and pins turned. The take out a link is asking for problems, at the most it is to get the machine to the shop repair. What will happen is the distance between the roller increases and they will end up hitting the sprocket in wrong place. I believe your sprockets have every other tooth design with a web between teeth. If you end up with a bushing landing in this space EXTREME pressure will be put on full track and final drives , LISTEN FOR THE LOUD POP OF SOMETHING BREAKING !
everett048
Posted: 10 Jul 2010 at 4:26pm |
Try general gear they do new allis m steering clutches
MNLonnie
Posted: 10 Jul 2010 at 4:28pm |
That's where I got my clutches, I think the fibers were $21 or $23 each.
everett048
Posted: 10 Jul 2010 at 4:35pm |
Yes John i think his name is very helpfull guy when i have had to use them quick responce to.
merjamika
Posted: 11 Jul 2010 at 6:49am |
My track chains are wore into the pins so I dont think i have much other choice than replacement
Coke-in-MN
Posted: 22 Jun 2012 at 8:32am |
bump
