Lower HP Round baler on AC 6060
ACkojack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACkojack Quote  Post ReplyReply Direct Link To This Post Topic: Lower HP Round baler on AC 6060
    Posted: 17 Jun 2023 at 6:28pm
Are there any round balers out there I could run on an AC 6060 with MFWD.?
Not looking to set a land speed record just for meadows and other smaller fields
I hire someone to do large baling jobs
Most are saying it needs more HP
Not a light tractor in my opinion
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 8:42pm
I pull New Holland 847 and 851 balers with my Oliver 1550  sometimes,its 55 PTO HP.on steep land I like to use the Oliver 1650 or AC 185.The 1550 easily pulls the 847 anywhere.
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 8:52pm
I did try my D 17 IV on my Hesston 5540 this summer.  When the bale became large and tight in uneven road ditches I wished I had my 4020 attached to it. The 5540 is considered 4 x 5 baler; I should behave and limit it to 4 x 4 when in road ditches.  Stability is no problem; ballasted, pie weighted rear tires and suitcase  wights mounted  on front.  When bale became near 5 ft the 17 could utilize a few more horses.
Edited by Marlyn nwia - 18 Jun 2023 at 4:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 9:43pm
What size bale are we talking ??    4 x 4 ??   4 x 5 ??
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 9:52pm
A John Deere 435 would be a nice match behind your AC 6060. Also a Vermeer 605F would be another good match
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 9:52pm
Heston 530 is a low HP round baler. Odd bale size though if I remember correctly. If it's for your personal use it should be fine. If it's hay to be sold it might be hard to find a buyer.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 10:07pm
Back when I was a tike I remember the neighbor doing an impressive job with an old Deere baler and a 160.   He later graduated to a slightly newer Deere behind a 6070.   We run a New Holland behind a 8030.  Dry hay and level ground I think my 6080 would handle it making baleage and pushing it the 8030 barks.   The New Holland belt balers make nice bales.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 11:35pm
 If the tractor doesn't have rear weights or fluid, I'd suggest you get some rear ballast if it's hilly ground.
 The older balers require 1 set hydraulic couplers to open/close chamber and maybe 1 set couplers / have a manual twine tie / or a 12 volt power supply to wrap twine around bale. We baled for our 60+ cows using AC 180 / 185 on VerMeer 605C & F series balers in our hilly ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 4:12am
Its a metric baler. 1 meter by up to 54" in diameter.  I called it roughly the same as a 4 x 4, when I sold them.  A d-10/12 series 3 pulled them nicely!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACkojack Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 6:10am
Was hoping to do 4 x 5 but 4 x 4 may have to work until I have a bigger tractor
I also have a Kubota FWA 7040 but the 6060 is heavier
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 7:11am
Another thing about round balers is they are one thing that spending a little more gets you a lot more a $2500 baler and a $45,000 baler will create a vastly different bale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 12:03pm
Probably true but my cows like to eat the hay not admire how it looks in the bale(LOL)
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 5:51pm
I have a claas rollant 62 that makes around a 4x5 soft core bale.
My series II D17 with the combine engine runs it fine . My Series IV
works a bit harder but gets the job done. I expect my new 7020 should
play with it.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 9:41pm
Older baler but I pulled a 605C Vermeer with 706 IH gas for 20 years, was a good fit, 706 about 65 hp.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 10:05pm
I run a cih 3450 on my Massey 1652 without issues. The hydro is nice!
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 12:19am
I second the Vermeer 605F round baler with it's two sets of hydraulics(one for rear door, one for twine tie). It's bale chamber is 6'tall x5'wide, but I always stop bale at 5' tall or whatever height you desire. Baler is nothing fancy. It has a bale height pointer gauge  Your AC 6060 mfwd should handle it with ease, given no extremes. The AC 6060's turboed 433 is a gutsy 4 cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 5:22am
Harder denser net wrapped bale sheds a lot more water when stored outside. Take a heck of a shed to store 1400 bales a year. Been feeding two year old hay with minimal spoilage and we are in a damp climate.
I can probably get double the hay in one of mine compared to a sponge of a bale.
Edited by victoryallis - 19 Jun 2023 at 5:24am
