Low/No Oil Pressure N5 Gleaner
New_NameXD05 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote New_NameXD05 Quote  Post ReplyReply Direct Link To This Post Topic: Low/No Oil Pressure N5 Gleaner
    Posted: 28 Mar 2025 at 10:09pm
Low/No Oil Pressure on Allis-Chalmers 670i (N5 Gleaner)
Hey everyone,
I’m working on an N5 Gleaner with an Allis-Chalmers 670i engine and having trouble with oil pressure. The engine was sitting for a while before I attempted to start it. When cranking, the oil pressure gauge barely moves, and when running, both the gauge and the oil pressure warning light indicate no pressure.
So far, I’ve:
  • Confirmed oil is flowing from the filters, meaning the pump is at least moving some oil.
  • Cranked the engine extensively, but it still won’t build proper pressure.
The pressure gauge behaves erratic at times. When I tap it, it drops below 0 and the backlight goes out.
I’ve ordered a mechanical oil pressure tester to verify, but in the meantime, I’m wondering if anyone has seen a similar issue with these engines. Could it be a stuck relief valve, clogged pickup tube, or an issue with the oil cooler? Any advice would be appreciated!
Thanks!
P.S. I've never used a form before so I hope I've posted this in the right place.
Edited by New_NameXD05 - 29 Mar 2025 at 3:37am
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 10:18pm
If it was driven to the spot it is now sitting, and then shut off, it has to have had oil pressure at that time, right ?  Get a mechanical gauge and verify that it does indeed have oil pressure. You have an electrical problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote New_NameXD05 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2025 at 3:35am
Yes, that is correct, it had oil pressure when it was originally parked. I'll definitely check it with mechanical gauge.
thanks
