Looking For
Pa'sOldA/C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa'sOldA/C Quote  Post ReplyReply Direct Link To This Post Topic: Looking For
    Posted: 22 Feb 2011 at 4:39pm
 Looking for a Traction Booster Cable for a D-19. I have called 3 different states and no one has one. I was told that a man in Missouri makes them, but nobody has a name.
 Thanks in advance Jimmy
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 4:49pm
D19s dont have a cable to operator the traction booster, its done thru a linkage under the tractor that connects the hyd pump to the large compression spring.  The cable you may be looking at is the tranport cable, it hooks to the right lift arm and runs up to a lever on top of the torque tube.   All that cable does is to allow the hyd pump to provide makeup oil to keep the arms in  the raised postion when in the upper 1/3 of the lift height.  Its to keep the arms up when going down the road more or less.   Most are broken off at the rear, you really dont need it to make the TB work.    HTH
