Looking for WD-45 part
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Looking for WD-45 part
    Posted: 25 Apr 2023 at 8:05am
Guys, help me out, a real good friend of mines Dad hit something with his plow and broke
the top link mount on his 45. I searched the net this morning and all I see are "U" shaped bar stock bent to go around the shaft. Is that all there is these days?
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 8:18am
There’s different types and a lot of them are owner fabricated. The broken part you have is scarce and pricey when you find one. Don’t toss yours in then scrap pile before you try to weld it first. Good luck.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 8:24am
Those haven't been made in decades. And they were a retrofit so not many made.they ocasionaly show up on E bay last one I saw went for $250. If you put one of the U shaped ones on put a clamp on either side to keep it from sliding back and forth on the rock shaft. A good welder could fix yours it is made of cast steel so welded it'll be as strong as ever. When you get it fixed put sway chains or brace on it swimming around is what caused it to break.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 11:24am
I would throw the Censored 3pt plow on the scrap pile and use a superbly designed snap-coupler plow the way the tractor was intended to be used.
Edited by PaulB - 25 Apr 2023 at 11:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 5:59pm
thanks guys, kinda what I thought, will pass on the info to his Dad.
Paul, I hear ya, but it’s not my place to tell a 88 year old man that has owned the tractor longer than I’ve been alive what and how to do it. I just try to help him when I can!
Ford 345C TLB
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 6:16pm
That looks just like the original WD45 top link...hard to come by, but they are still out there, if someone wants to part with one...good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2023 at 8:07pm
Take out the 2 bolts and take the parts to a welder itll be good as new
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 6:52am
Take that one off. Weld it up and reinstall. If you don’t weld take it to a welder and have it done. Those are good brackets. Fix and save it. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2023 at 7:43am
if it’s allis part what’s the part number
This page was generated in 0.085 seconds.
