looking for metric bolts |
Roger Mn
Joined: 12 Sep 2009 Location: Preston Mn Points: 109 |
Topic: looking for metric boltsPosted: 30 Nov 2010 at 6:53am |
Need 12 M20 X 2.00 X 65mm Roger
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2808 |
Posted: 30 Nov 2010 at 7:05am |
Don't know if you are close to a specialty bolt supply house. In Omaha, we have Nebraska/Iowa fastener. They had a 6" long metric bolt I needed, could even choose the hardness.
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 30 Nov 2010 at 8:21am |
I think Lowes has Metric, not sure if they have your size/threads.
Fastenal also has, check their website.
Goose
Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
Posted: 30 Nov 2010 at 8:40am |
I used to own a Yamaha motorcycle and snowmobile shop. We dealt mostly with metric. If you can't find any, let me know and I can probably get you some. Otherwise, try any Japanese motorcycle shop, such as Yamaha, Honda, Suzuki or Kawasaki shop. Perhaps a local foreign car dealer would have it, such as a Honda or Kia dealer.
Jeff Z. NY
Posted: 30 Nov 2010 at 8:45am |
Just look in your yellow pages for a dealer under Bolts & Nuts and also under Fasteners-Industrial & Construction.
CTuckerNWIL
Posted: 30 Nov 2010 at 8:56am |
Gerald J.
Posted: 30 Nov 2010 at 9:24am |
www.mcmaster.com has them in grade 8.8 and stainless steel but 2.5mm pitch, not 2mm pitch. The grade 8.8 is partly threaded, the two in stainless steel are fully threaded hex head. I didn't look for socket head. http://www.mcmaster.com/param/asp/psearch.asp?FAM=cap&FT_110=48195&FT_104=141&FT_1349=232268&FT_136=45180&FT_379=122672&FT_147=60655&FT_137=31621&FT_1464=61711&FT_182=47456&FT_2025=130285&FT_2234=257255&FT_2029=100006&ppe=3&session=desc=Screws;cap;110=48195;104=141;1349=232268;136=45180;M;I $2.99 each for grade 8.8
Or just bring up www.mcmaster.com. Click on bolts, click on hex head, click on metric, click on 20 mm diameter, click on 65mm length. The two stainless are quite a bit more costly that the zinc p]ated steel. They do have them in socket head also, but still 2.5 mm pitch. Fastenal has 1.5mm pitch with 1- 2 weeks delivery time, $5.70 to $15 each. 2.0 mm may be a tough size to find. Gerald J. |
JoeO(CMO)
Posted: 30 Nov 2010 at 10:17am |
What/ where are these being used? It might be easier to match from that angle.
Roger Mn
Posted: 30 Nov 2010 at 10:32am |
putting loader brackets on a deutz DX130
Dale H. ECIL
Joined: 11 Sep 2009 Location: Paris, Il Points: 690 |
Posted: 30 Nov 2010 at 6:57pm |
I needed a metric bolt for the draw bar on my 5030 a couple years ago, looked every where, finally tried Fastenal and they had it.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Dave King
Posted: 30 Nov 2010 at 7:11pm |
John Deere usually carries metric, but Fastenal is better.
Joined: 11 Sep 2009 Location: illinois Points: 89324 |
Posted: 30 Nov 2010 at 8:21pm |
you might want to check your thread pitch again.. 2.0 is not a standard size..
Roger Mn
Posted: 01 Dec 2010 at 7:28am |
I was able to find the some bolts . thanks for the help Roger
