Looking for Lift Arm Ends
StanGreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanGreen Quote  Post ReplyReply Direct Link To This Post Topic: Looking for Lift Arm Ends
    Posted: 21 Dec 2022 at 8:14pm
I have a 1954 Allis-Chalmers WD45 I am in the process of restoring. The only thing (so far) I have not been able to find are the Lift Arm Ends. I am only interested in the 1954-56 style.
Does anyone have a set they are willing to part with or know where I can find a set?
Thanks,
Stan Green
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2022 at 9:52pm
Part numbers
326241&326242 latch assy used prior to Jan 1954
326801&326802 latch assy eff Jan 1954 thru 1955
326530&326531 latch assy eff April 1955 thru June 1956
330134&330135 latch assy eff July 1956
Then eventually the numbers were replaced with 243996
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanGreen Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 6:49pm
Thanks for the info, Mikez.
So when you say "Then eventually the numbers were replaced with 243996" does this mean they stopped making four models and only made 243996?
Thanks,
Stan Green
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 7:02pm
The last couple generations of lift arm latches were amidextrious and worked right or left with the setscrew always on the outside of the lift arm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 7:05pm
The sets of numbers are left an right part number. I’m not sure exactly  what year but for example  if you look up 330134 in master numerical book from 1969 it will say use 243996.
And like dr says. Went to one latch instead of L and R. And little heavier built
Edited by Mikez - 22 Dec 2022 at 7:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanGreen Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 7:35pm
Thanks.
I am more looking to get it back to how it came out of the factory. Not so much on making it the best for work. It will be mainly a show tractor with maybe some light farm work. So I want to sick with the earlier version lift arm ends.
BTW: I do have one broken one and the number on it is 326532 so it does not match any of the numbers posted here. This one has the set screw on the right. It looks like the one in the picture I posted but the other side.
If I can find one matching one, I might be able to restore the one I have.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2022 at 8:27pm
I’ve got a set of the old style, they need new springs. Text me if interested 404-358-2635
1950 B, 1952 pulling wd, and 1954 wd45
DB74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DB74 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 3:22pm
I have a set.
Shoot me an offer if interested
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 4:24pm
At time they were made the top latch was separate part number and could be ordered to replace. I think
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2022 at 5:43pm
got a few sets also. if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanGreen Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2023 at 8:32pm
Thanks for the offer dawntreader74. I did come across one and I have one I think is restore-able. So, I think I am set for now.
This page was generated in 0.434 seconds.
