Looking for Hd6 part
Jgriffis03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Topic: Looking for Hd6 part
    Posted: 23 hours 2 minutes ago at 9:42pm
I’m needing the intermediate shifting shaft. If anyone has one for sale I would greatly appreciate it. Number 5 on the callout for parts diagram of the shift tower. Thank you in advance
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 24 minutes ago at 7:20am
Have made that exact part a couple of times in the past. 4140, or 4340 Alloy steel will offer enough surface "toughness" without heat treat to last. Have a machinist bore the shift handle, (#6) round and bush this with oilight bronze, or drill and tap your new shaft, (pivot pin) for a grease zerk, and cross drill for grease path keeping it tended to. While the shift lever is out always a good idea to have the lands where the pivot screws butt against cleaned up also. Makes for a nice tight shifter again as long as the shifting forks and shafts are in good condition. These always need touched up also as wear items.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 13 minutes ago at 9:31am
 What’s the part number
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 59 minutes ago at 9:45am
I’m sorry all, it’s number 6 on the callout.
P/N: 098089
Or
P/N: 086705
It’s the whole lower shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgriffis03 Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 58 minutes ago at 9:46am
The whole shift lever is missing haha. My issue is that I’m not sure I can get one machined without precise measurements of one first.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 37 minutes ago at 3:07pm
Maybe check with General Gear and Machine in Boise, Idaho
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 9 minutes ago at 5:35pm
Definitely be cheaper to obtain used, but I can make one if needed.
That's All Folks!
