Looking for D15 diesel main bearings |
Rltool
Joined: 17 Jun 2013 Location: Middleville ,MI Points: 1833 |
Topic: Looking for D15 diesel main bearingsPosted: 26 Jan 2023 at 7:16am |
I’ve got my D15 diesel Industrial backhoe engine tore down. Im looking for the main bearings for the crank shaft. Which is getting ground to .030” under. Any leads or help would be appreciated.
Ray Walker (269)804-5984 |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Posted: 26 Jan 2023 at 10:52am |
Good Luck with your search.
I just rebuild the Diesel in my D15 2 years ago and It was a struggle to find standard bearings. (Or any parts for that matter) these thinks pop-up once in a while. hopefully someone here can help. You can check with: Pfouts family farms in Ohio 1-330-569-7037 they advertise on this site. Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Larry in NC
Posted: 26 Jan 2023 at 11:35am |
I Googled and Yesterday's Tractors and others have the std. main sets. Instead of turning the crank under, is having it built up and turned to std. and option?
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11873 |
Posted: 26 Jan 2023 at 4:27pm |
Aren’t they the same a D17D? Just fewer of them?
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 26 Jan 2023 at 5:32pm |
Rltool
Posted: 26 Jan 2023 at 6:00pm |
I’ve talked with All State Ag, Reliance & Jen Sales. All out of stock. If I could find a standard set. Having the crank mains built up is an option.
Joe, those bearings are for the D17 or D19. I believe this engine to be a 175cid. Edited by Rltool - 26 Jan 2023 at 6:06pm |
Rltool
Posted: 26 Jan 2023 at 8:43pm |
Joe(TX) I looked at the specs for the D17 D226 diesel compared to the D15 D175 diesel. And it looks like those main bearings will work for either one.
Thank you for the information. Ray W. |
Pfouts Family Farm
Joined: 05 Dec 2018 Location: Hiram, Ohio Points: 177 |
Posted: 27 Jan 2023 at 11:21am |
Ray, I should have a set, give me a call. Pfouts Family Farm LLC 330.569.7037 Mark |
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 30 Jan 2023 at 6:40am |
They are all the same. D15D, D17D, D19G/LP, and D19D all use the same main/rod bearing.
I ran into this when I redid my D15D Years ago. No sets in stock for a D15D (175CID) but PLENTY of stock for D17D (262 CID). Just ordered them for a D17D and had some main bearings left over that I didnt use. All the 175CID engine is is a 262 6 cylinder with back 2 cyinders missing. Bore, Stroke, rod, are all the same
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
