Looking for a WD45 wide front end
Tabnavy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tabnavy Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a WD45 wide front end
    Posted: 27 Dec 2020 at 4:47pm
I’m located in Indiana. Looking to swap out the narrow for a wide front. Any tips on how to modify or what to look for to make sure it will bolt up. I hear there’s a 3 or 4 bolt pattern and that’s all I have so far.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 5:52pm
There's one on craigslist kirksville mo. 400 bucks
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 6:26pm
link to Ad
Don't see the large front end casting for between the frame rails
https://kirksville.craigslist.org/grd/d/kahoka-ac-wide-front-end/7249408305.html
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 9:48pm
It's also missing the steering arm and pivot plate
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 10:04pm
pm sent'
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tabnavy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 3:40pm
So it looks like I would need to change the whole front end as this one is all one piece.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 4:54pm
It would be much easier to buy a wide front tractor!  I have two, D14 and D17.  Both have power steering.  I live south of Flint MI.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 7:10pm
I have the front end with pivot plate, no bolster 300$ in iowa
phil
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 8:26pm
I have both 3 or 4 bolt wide front for sale $500 for everything to change over
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 10:46pm
A word of advice.
Loosen all the bolt s on the left frame ( as you are sitting on the seat) and spread the frame rails to remove the old narrow front. It's most likely been on there for more than 62 years. They don't come out very easily.
Farmerjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmerjim Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2021 at 11:21am
I have everything you need and it’s a 4 bolt hanger. I’m an hour away from Chicago, where about Indiana are you ? Thinking $450. No welds pretty good shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 12:41am
Be aware that the bolts in the bolster may twist off. If happens on removal no big deal if not reusing it. Check replacement for twisted off bolts before install. Get some new GR5's for install. The switch is rather easy if properly supported and loosening one rail up is good advice. They are a snug fit otherwise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tabnavy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 6:25am
Thank you for the information. My intent is to check engine out (had oil in water - freeze plug on head blew out and it cracked ) I just got the engine removed yesterday and started pulling pistons to check sleeves as the middle two pistons had water in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tabnavy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2021 at 6:26am
South of Indy.
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 7:24am
I have a bolster for a 3 bolt front end.
This page was generated in 0.219 seconds.
