looking for a good 816 loader backhoe shuttle
david a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote david a Quote  Post ReplyReply Direct Link To This Post Topic: looking for a good 816 loader backhoe shuttle
    Posted: 03 Sep 2018 at 6:59pm
looking for a good forward revers shuttle for a 816 close to Wisconsin. Also a hydraulic pump for the loader and the steering pump. As long as I working on it would like to fix most of the problems before the snow flys
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 10:00pm
think rebuilding your unit would be the solution to a problem
Check under some of the 715 posts as there is a supplier of parts that might help you find what you need
Post Options Post Options   Thanks (0) Thanks(0)   Quote david a Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 4:02pm
Thanks is there a good way to get it down and out from under the tractor. Have a transmission jack. but i think the shuttle might be a little heaver than a transmission
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 8:14pm
wonder if sumerix implement could lead you on parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 4:29pm
They might have access to parts , - its a unit that should come out with transmission jack as the support for it
