Looking at a D14 |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2609 |
Topic: Looking at a D14Posted: 10 Sep 2023 at 12:19pm |
And she says the hi Lo hand clutch works good but there’s no neutral. Does this mean disaster? Thanks. Dana
Blue Skies and Tail Winds
Dana |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5469 |
Posted: 10 Sep 2023 at 1:45pm |
Just wonder if she says that because it has the normal crepe while in neutral common in the D series?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 10 Sep 2023 at 4:47pm |
Take the access door off and see if the brass shims are out of the PD clutch. Also if the PD fluid is too thick, or moisture laden (cloudy or milky)...
captaindana
Posted: 10 Sep 2023 at 5:01pm |
Yup I’ll have to go and see
Dana |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 10 Sep 2023 at 5:59pm |
I would not be worried about it. They are easy to work on. Could be creeping and they are assuming neutral is out.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 722 |
Posted: 10 Sep 2023 at 6:14pm |
This may or may not be relavant. My d14 creeps harder when its cold. Warmed up very little
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 10 Sep 2023 at 6:55pm |
All 4 of my D-14s never had a true 'neutral'..... creep a little, unless plow was acting as an anchor..... yes, thick oil, it's creep more.... What could be an issue is the ' 3rd gear pop out when backing off speed' problem.... or PTO lever dribbles some oil or rockshaft ram seal / line leak but they are GREAT tractors !!! query... is it a 6 volt or 12 volt version ?
AC720Man
Posted: 10 Sep 2023 at 7:06pm |
As the transmission oil warms up the issue becomes less evident.
captaindana
Posted: 10 Sep 2023 at 7:25pm |
Yes I have many hi lows my whole life just not a D14. Pretty sure it’s prolly the creeps😆. Thanks y’all!
Dana |
Travis2766
Joined: 26 Aug 2015 Location: Amherst, Wi Points: 439 |
Posted: 10 Sep 2023 at 7:28pm |
My D15, D17 and 190XT all have varying amounts of creep in neutral, I wouldn’t worry.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
AC720Man
Posted: 10 Sep 2023 at 8:44pm |
Dana, your herd will look even better with a D14 added to it.
captaindana
Posted: 11 Sep 2023 at 5:14am |
I’m debating here on my second cup of coffee…why buy another? Another alternator conversion, another battery, another fluids change, another yearly oil and filter and etc etc etc. Twenty three oranges are enough…..but dang I always wanted a pristeen 14….
Dana |
Posted: 11 Sep 2023 at 6:06am |
All the more reason to go and get it !!!
Travis2766
Posted: 11 Sep 2023 at 7:24am |
Never have too much orange!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 11 Sep 2023 at 3:56pm |
You can always sell it off if you decide it was a mistake.
DSeries4
Posted: 11 Sep 2023 at 4:05pm |
Pristine D14's are very hard to come by. If you find one, GET IT! Most have had craapy repaints done. I have 3 original D14s. They are always the "go to" tractor for light chores around the farm. If you find one with factory power steering, even better. No need to convert to an alternator - I am still running generators on all of mine. Get them professionally rebuilt and they are good to go. Dad on the 1958 that his father bought in 1960: ![]() 1959 That I bought for $200. Sat in a barnyard for 15 years. Engine was rusted solid. ![]() 1960 I bought 3 years ago from someone's private collection. ![]() |
captaindana
Posted: 11 Sep 2023 at 7:34pm |
Oh man you guys are killing’ me! Yes it has power steer and original paint. I changed oil and filters and antifreeze and air filters in the 200 then 175 then 7020 then D17 III then WD45 WF just to keep my mind off that 14 today. Tomorrow I have 10 more to do trying to forget the 14!
Dana |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 11 Sep 2023 at 8:35pm |
Factory power steering?
That's a "must buy!" Darrel |
AC720Man
Posted: 11 Sep 2023 at 9:00pm |
I’m partial to those 1959 black bar grill D14’s and D17’s. Best looking grill they ever made IMO
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2307 |
Posted: 11 Sep 2023 at 9:17pm |
Would rather have a D14 than a D15.....
it might be because it had Power steering added and it works FANTASTIC !!!!! I have spent MANY an hour on our D14 doing EVERYTHING but heavy tillage. GREAT small tractor !!! |
LaJaMe
Joined: 14 Sep 2014 Location: wisconsin Points: 172 |
Posted: 11 Sep 2023 at 9:39pm |
When my Dad was a dealer Late 50's to Early 60's, Our demonstrator tractor was a NF D14. I spent alot of time in that seat and loved every minute. We didn't have a truck so the 14 was used to pickup and deliver equipment. Great little tractor !!!!
darrel in ND
Posted: 12 Sep 2023 at 9:29am |
Post some pictures of it after you get it home, Captain !!
Darrel |
