Looking @ 6080 with issues input needed. |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2880 |
Topic: Looking @ 6080 with issues input needed.Posted: 19 Jan 2011 at 8:19pm |
Talked with someone who has a 6080 that has hydro oil leaking from the pump into the crankcase what's wrong with it? The guy also says it's a cab tractor that never had AC is that possible? He had the rear end rebuilt a couple years ago is that common we have two 6080 's one with 8000+ hours the other with 6500 + and to our knowledge the rears are untouched.
Posted: 19 Jan 2011 at 9:09pm |
Drive shaft seal on the hyd pump has failed and maybe a bearing on the shaft. Rearends aren't too common to fail but when run low enough on oil they sure will....also depends on what the failure actually was..(differential, parking brake, wheel brake seals, etc).
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 19 Jan 2011 at 9:25pm |
Air conditioning in the cab is an option according to my owner's manual. Right on the cover is a tractor that does not have an AC compressor.
