Look what followed me home
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Topic: Look what followed me home
    Posted: 07 Apr 2011 at 6:22pm
Picked up another SFW set up.
Edited by BILLP-SE-MI - 07 Apr 2011 at 6:24pm
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 6:35pm
Nice find, I really like the way the single fronts look on a tractor.
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:00pm
I have never driven a SFW, do they steer easer?  They should not have the "kickback" on uneven ground like a standard two wheel narrow front.
Dennis
Mark J. N.Y. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark J. N.Y. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:23pm
And you wanted me to bring you one of mine.................LOL............. Whats up with that Bill????
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:33pm
I went up to pick up a C cultivator & rockshaft he had this in the weeds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:41pm
Thanks Mike, Mark ya never know what ya find, just got them today.
Dennis here's my WD . CA  & C sfw
Edited by BILLP-SE-MI - 07 Apr 2011 at 7:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 8:18pm
Bill, have you ever weighed the single wheel setup and compared it to a normal narrow front?   I wonder if it's lighter or heavier?   Seems to be a hair less metal up front but that wheel and hub looks pretty stought.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 8:22pm
One more question, does the single front wheel setup bolt right up to a WD/WD45 wide front bolster like a picker narrow front does, with the five bolts or does it have it's own special bolster?
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 9:00pm
Bill, ya dang dog.
I think I know where all the SFW's are hiding in michigan, and it aint at Kent's place! lol
Nice find!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 9:05pm
Yes, the single fronts and the tricycle adapters bolt on using the same 5 bolts.  Michael
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 11:09pm
  The weight of  just the fork , cast  wheel center, and tire is about 202-5  lbs. I just weighed the cast piece that goes between the frame rails, 137 lbs. So the total weight of a SFW front end  342 lbs +/-. This the bolt on fork type.
Have a good one  BILL
Edited by BILLP-SE-MI - 09 Apr 2011 at 6:15pm
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 11:09pm
The last single wheel setup is different...I have to change the whole front pedestal with it.  I also have front hubs that are solid steel and one that is pressed steel.  The pressed steel has a yoke that looks like Bills.
ALLIS EXPRESS!
This year:
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 5:55am
Eldon. If you have a single front for a W series tractor that is one piece where you have to change the whole front pedestal, it will be from a WC or early WD. They are hard to find.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 8:01am
Looks like a nice haul!  Let me know if you decide to part with the front gang lift tubes.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 9:19am
I thought it looked like you were building another C there....
Planning on stopping in at the end of the month to pick up that stuff you have for me. I'll call you later this month to work out the details.....
Edited by GlenninPA - 08 Apr 2011 at 9:20am
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 10:36am
Just checked and both of my WD single fronts are that way....probably rarer because they came from the factory that way, whereas the others probably could have been bought to convert a wide front tractor when being used with a mounted picker?? Just a theory.....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 10:52am
The WC and early WD single fronts are what I call non detachable.  They are a true single front, you can't switch to a wide or tricycle without switching out the bolster.  Also the yoke is about one inch narrower that the tire, so to get the tire off you have to deflate it and even then it is hard to get out.  On the later WD and all WD45 single fronts, they are just a bolt on to any of the standard wide front ends. So definitely, the non detchable single fronts are more scarce and sought after if you have a WC or early WD.  I don't recall if I have seen any serial number breaks on when they changed from the early to later style.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 10:52am
Ok, Eldon now you have us interested can you post some pictures of the 1 piece single front? I always wondered where they pivoted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 11:06am
I found my IT manual and it shows the 2 different styles. The s/n break on the WD is at 25129, but the one WD I have is 75xxx, so I would guess someone did some changing somewhere along the line.  I also noticed that that tractor had cultivator brackets on the front at one time, the seller had told me his dad was from the midwest and had owned the tractor a long time.  I bet he hauled it out this way and converted it for veggies...
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2011 at 6:36pm
Here's  some pictures of the two types of forks.
