Lonestar pull Today
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: Lonestar pull Today
    Posted: 12 Sep 2015 at 6:30am
I weighted up the old CA to pull in #4000 competitive stock. Wish me luck in this David verses The Goliaths class.
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2015 at 7:30pm
How did you do, and what was your other competition?
We had another pull today on light sandy soil and got a 1st in 3200, 3rd in 3500 and 3750.
DeWayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2015 at 7:22am
Lost to a pair of Olivers in 3500 and 4000. Not by a whole lot though.
I'm seriously rethinkin going to smaller rears
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2015 at 8:50am
Ken,
Wife did'nt fare so good this wk end either. Hard track with a bit of goo on top after water. 16.9's just would'nt hook. Got beat by the narrower track tires which is usually not the case. My WD took KOH @ 3750 3mph with 10 others including a couple of hot Olivers,
a sweet win!
dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2015 at 4:47pm
Win some loose some. Gettin beat by the narrow tire tractors is getting to be pretty regular here lately. Is same number of pounds spread over a larger area make you spin easier? Got me scratchin my head for a mathematical solution.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2015 at 6:34am
Ken,
If you figure it out, plz let me know as our final pull of the year is coming up with a similar type track but indoors. We also had a bearing failure on the drive axle (outside) which took out the final drive gear and the axle gear. Give me something to do in my spare time tho.
What distance did you pull at 4k? Quite a load for the CA!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2015 at 7:43am
What distance did I pull? Not far enough. Plenty power with a stock engine in first gear. Just can't get it to keep from slipping the wide tires even with all the added weight behind the rear axle or above and close ahead of it. Something is not adding up to TRACTION. The heavy engine is way to far ahead of the rear axle.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2015 at 8:20am
I've pulled 3500 and 4k depending on what other tractors showed up. Thin classes, I will pull for the fun of it. Stock it does OK, just need to load a lot of weights!
I have 11.2x24's on it.
Charlie
This page was generated in 0.099 seconds.
