Unofficial Allis Homepage
Forum Home Forum Home > HELP! > Forum Support Only - No Tractor Questions
login problem
Frank View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frank Quote  Post ReplyReply Direct Link To This Post Topic: login problem
    Posted: 24 Aug 2020 at 3:23pm
Tried logging in several times and was rejected each time. I then tried registering with the same user name and password and got a message that they were already used.  What gives?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 6:39am
Sometimes, if you get rejected, you have to scroll down that page to see why.  If you enter the wrong password it can happen.
 User name and password are case sensitive.
 If you post your registered user name, someone can help you get logged in.
Quick Reply
Name:
Message:
   NoFollow is applied to all links from this forum
 Enable BBcodes
Security Code:
Code Image - Please contact webmaster if you have problems seeing this image code  Refresh Refresh Image
Powered by Web Wiz CAPTCHA version 4.04 wwf
Copyright ©2005-2013 Web Wiz
Please enter the Security Code exactly as shown in image format.
Cookies must be enabled on your web browser.
