Location of WD45 decals
tnb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnb Quote  Post ReplyReply Direct Link To This Post Topic: Location of WD45 decals
    Posted: 20 Mar 2012 at 8:51pm
Can somebody post pictures of where all the small decals go on a WD45? It was a two year project, and I have forgotten where all the warning stickers go. I bought the whole set; such as, keep hydraulic lever down when not in use, grease universal joint daily, and two-snap cupler decals, and transmission in neutral before dismounting. If anybody had pictures that could be helpful, or an explanation would be helpful as well. We have the side Allis Chalmers and WD45 on, as well as the sticker on the side of the battery box and oil bath air filter. Thanks for any help!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 5:49am
An original Allis colour brochure like this one that just sold on ebay would help.
I have some but they are about 1500 miles away right now.
Gary
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 6:43pm
snap coupler sticker goes on the left side of the snap coupler bell 1/2" back from the open end with the bottom edge along the top of the middle seam, universal joint decal goes on the steering shaft about 1.5" below the lower shaft support so it can be read with front wheels turned straight, hydraulic lever decal goes on the horizontal crossbar on the bottom of the quadrant underneath the hydraulic lever on the left side, i believe the shift into neutral decal goes on the flat top of the dash piece. if you have the drain radiator decal it goes directly under the draincock on the left side of the engine block
This page was generated in 0.103 seconds.
