loader ?
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Topic: loader ?
    Posted: 10 Feb 2012 at 8:30pm
what allis chalmers  square tube style loader will fit the model 170 allis chalmers brakets i have mounted on my d 15 i found a allis loader but no tag it is 40" across were the arms go into the tops of the brackets just wondering i have been driving all over to get answers but cant get lucky yet help would be great i seen a picture of a d 15 with a allis loader but it had plates welded on the arms and im also wondering if they are factory? if so the loader i found should fit into my bracketsSmile figures crossed drove 2 hours one way today to find out a Allis Chalmers so called loader turned into a Vaughn oh well i am picky so it will be right when i am done have the bucket and brackets now i need the boom arms or frame what ever you want to call it the brackets i have call for 40" across though is that right? i hope so the head lights would clear again if that is the case the paulson loader i had was to narrow so i had to take them offConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 9:16pm
alomst forgot to mention i am ihooking up a "cross" two way open center spool valve to plumb in and run the loader lift arms i was curious if i hooked a ball valve into this circut would it work still or would the loader fall to the ground as soon as i shut the supply off???
